Go to Post Do you mean...? If so, it's illegal under . (insert your favorite reminder to read the manual here) - EricH [more]
Unread 29-01-2008, 11:49
Chaos204's Avatar
Chaos204 Chaos204 is offline
AKA: Jordan
FRC #0204 (Eastern Robotic Vikings)
Chaos204 is on a distinguished road
Send a message via AIM to Chaos204
Best Sprockets
at this point the only way i can see our arm powered is if I use the keyang motor with a small sprocket and a large sprocket attached to the pivot of our arm. I wanted to do a winch with a lever but that seems to be out because of the 80 inch envelope. If there are any other suggestions they would be greatly appreciated. The big question is where should I get the sprockets?
Andymark has some and so does IFI. our team hasn't done anything with chain in years, so i am making it up as i go along...
2005 PARC FINALIST
with 84 and 176
E. R. V. is on its way
Unread 29-01-2008, 11:52
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Best Sprockets
McMaster and MSC both carry a large variety of sprockets.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 29-01-2008, 11:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Best Sprockets
We used a large IFI sprocket to move our arm last year, it worked just fine...we made a pivot design that let us put the standard 1/2" bore flanged ball bearing (as used on IFI wheels) in the center of the sprocket.
My guess is that you need it to be light weight, so the aluminum sprockets offered by IFI and AndyMark would probably be the way to go.
Unread 29-01-2008, 14:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Best Sprockets
Along with these, Martin Sprocket and Gear has a good selection of gears and sprockets.
Art Dutra IV
世上无难事,只怕有心人.
Unread 29-01-2008, 15:34
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Best Sprockets
remember, you shouldn't go over 100 (?) teeth on a sprocket as it will lead to the chain not meshing properly since chain does stretch slightly.
good luck, Vivek
"we don't build robots, we build people"
Who's the best vendors for getting 25 chain and sprockets? waialua359 Kit & Additional Hardware 5 08-01-2008 22:17
sprockets Adama Technical Discussion 12 14-01-2007 14:05
Best Matches (best fought not score) ne0x0n General Forum 13 01-04-2005 12:40
sprockets BBFIRSTCHICK Technical Discussion 21 09-02-2003 01:01
sprockets Greg Needel Technical Discussion 0 23-04-2002 12:30
