#7
Re: IR Jamming from 2 or more remotes - results
Actually, it is about what your robot does with the command, because if you are really clever with your programming, your robot will only need one command at the beginning of hybrid period that will tell it what to do for the rest of the period, and you can just ignore the IR inputs after it receives that one command. Jamming problem solved.
| IR REMOTES | team550 | Control System | 2 | 15-01-2008 00:00 |
| Results from Drexel, thanks from 365. | archiver | 2001 | 1 | 24-06-2002 02:44 |
| Results from GLR? | archiver | 2001 | 0 | 24-06-2002 02:44 |
| results from regionals | archiver | 2000 | 0 | 23-06-2002 22:31 |
| More Mid-Altantic Results | archiver | 2000 | 11 | 23-06-2002 22:26 |
