Go to Post There is no MILSPEC standard for pool noodles. - Rick TYler [more]
Unread 29-01-2008, 13:17
Donny_Fresh Donny_Fresh is offline
no team (Freshies and the rockets)
Rookie Year: 1987
Donny_Fresh will become famous soon enough
Unhappy <h1>FRC=Trouble!!</h1>
Man...our team was so close to being perfect and now we've been faced with several new problems:
1: The Rotary Valve broke off the robots hollister belt.
2: The telecom 3000 E series that was included in our deluxe KOP was thought to be broken, but it actually just needed new batteries, but we soon learned that the spindle charges on the telecom would snap in half.
3: The shaft output valve that we purchased to increase speed using pnuematical parameters only runs at 90 psi which is illegal in the game.
4: The Flux Mcdocizer will only run when charged at 900volts which anyone reading this would know is too power to harness under F12 protocol which forbids the use of more that 20ohms per instant use.
5: We purchased a 70/10 which is a cheaper version of the 80/20 which actually works a lot better in our opinion just because is was manufactured to percisly glide with the precision of a double mono count sproketor. The only problem is that its made of a poly carbon ion which fused with a special quartzite that we used to frame the body will produce a semi titanium oxy magnesium which has a net fg of about 230newtons or 347lbs for those of you using the english system.
6: And finally our mascot is going to be Europe duing the competition so who are we gonna get now??
so yea those are our problems. If anyone knows how we can get these things to work please comment. also tell us how your doing!!
Unread 29-01-2008, 13:28
Re: <h1>FRC=Trouble!!</h1>
*chuckling* Aren't you ahead of the game by about 30 years? Especially with item #4?
OK, maybe #6 is real and current...
Unread 29-01-2008, 13:30
If that balderdash is all you can find to complain about, I think you have more problems than you realize.
Unread 29-01-2008, 14:31
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
lol thats funny
Unread 29-01-2008, 14:51
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
lmao.... this guy.... is nuts!
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
**FIRST Email**/FRC Online Survey and FRC Team Forums AmyPrib FIRST E-Mail Blast Archive 4 28-03-2006 13:07
2005 FRC vs. 2004 FRC CronosPrime1 Programming 2 23-02-2006 09:30
**FIRST EMAIL**/2005 FRC Game Design Communication to FRC Teams Goobergunch FIRST E-Mail Blast Archive 1 06-01-2005 09:29
