Re: pic: the inventor file
Oh, I didn't realize the need to rotate, so what I said was wrong...sorry!
If the arms only need to rotate over the lift when the lift is in the full up position, then you could connect both sides together with a shaft, and then you would only need one motor. I can not tell enough about your design to know if this would actually work, though. Does the center part slide all the way to the top of the channel? |
now i see, we thought about it but it wont work with 1 shaft.
what u suggested might work i will check it out! thanks alot! |
| How to use the data obtain in one C file to another C file? | tommy_chai | Programming | 8 | 11-01-2008 02:17 |
| tank tread inventor file | SgtMillhouse648 | FIRST Tech Challenge | 0 | 14-09-2006 11:12 |
| Huge Inventor File Sizes | Robert Thacker- | Inventor | 8 | 08-04-2006 12:43 |
| Help! making an inventor file into an autodesk file | kjhobin | Inventor | 5 | 19-03-2006 23:04 |
| Inventor File to Powerpoint | yamo18 | Inventor | 5 | 25-01-2004 14:17 |
