Go to Post Step 1. Understand the game and how to win the match and the event. - Chris Fultz [more]
Unread 29-01-2008, 13:56
Re: Serious Problem of Unknown Origin
The repeated initialization message says that your program is causing the Robot Controller to reset repeatedly. squirrel probably has it pegged: the current draw from the motors drops the voltage to the point where the RC doesn't have enough to keep running.
But in case that's not the problem, which timer are you using? How long did you set it to run before causing an interrupt? Did you remember to reset the interrupt flag in the service routine?
One more thing: are you using PWMs 13-16? Using the standard IFI code, those four outputs don't play nice with interrupts.
Unknown Device ID(0) DavidGitz Control System 13 28-01-2008 20:28
SERIOUS COMPRESSOR PROBLEM simeon1770 Pneumatics 6 18-02-2007 21:07
FIRST Unknown irishninja General Forum 4 24-04-2006 08:45
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
