Re: Serious Problem of Unknown Origin
We connected a fully charged battery pack to the backup inputs on the RC, and we no longer got the "IFI>IFI 2006 User Processor Initialized" message. However, the motors are still not spinning at their normal speed.
Did you try connecting a fully charged big gray 12v battery to power the robot? A discharged battery will cause the symptoms you are describing, and it is very easy to try this first, and save yourself a lot of frustration.
I only offer this advice repeatedly because I have spent many hours of my life trying to fix similar problems that were caused by discharged batteries..... |
If the RC is switching to the backup battery to stay alive, all PWM outputs are disabled. Replace or recharge the main battery.
Thanks everybody for the suggestion, we are going to try them tomorrow when our teacher is here to provide us with a fully charged gray battery/battery charger.
Mr. Anderson - We meant that reverting back to the default code did not resolve the problem. By "behaved like before" we mean that the motors still spun at a very low rate. |
Yes, we have tried resetting.
Ok well in that case what I would do is run the programing, and test your voltage everywhere in between the IFI board and the power source and the motors. Maybe the trouble is in the motors... have you driven the robot yet? Maybe there burned out?
#7
In addition to what everyone else has been saying (charge your battery or swap it out for a freshly charged battery), your OI should report battery voltage > 12.4 volts for a nice happy robot. Once you get there, make sure your Victors are calibrated. Neutral is orange, max in one direction should produce a green led (at the Victor), max in the other direction should produce a red led (at the Victor).
#8
Thank you for your suggestions so far.
Currently we are charging one of our 'big greys' and will see what happens when we try again with it. |
#9
We've just tested our robot with a new battery, and the problem is resolved! The motors are now spinning at their normal speed. Thank you everybody for your prompt replies and "gracious professionalism".
#10
I'm glad to be of help!
Do you understand why the robot behaved as it did when the battery was discharged? It might take some thinking to figure this out, but if you develop an understanding of how batteries work, specifically how the available voltage changes with charge state and current load, it should make sense. |
#11
Do not ever set your battery on concrete.
I don't understand the chemistry/physics behind it, nor do I ever intend to delve into the science of why it happens but something about rebarb, concrete and long half-life radiation drains your battery if it's in close proximity to concrete. I saw it happen repeatedly at the VA State Fair with our robot and rather than trying to understand why I'll just accept the fact that it happens for now.What we saw was that the charger would say our battery was fully charged. We'd then transfer the battery to the robot and place it on the field. At the start of the match, the bot would move extremely slowly, and the OI would indicated ~7V on the battery. About 15 seconds into the match, the voltage would go UP and the robot would act normally. Who knows why ? What I do know is, we do not place batteries on concrete any more and we haven't seen the problem since.If you thought your batteries were charged and then you get these results, perhaps this is why. |
#12
The battery on concrete thing likely has to do with temperature, since colder temperatures slow down the chemical reaction that releases electricity (that's my incomplete understanding of it)
#13
If your robot was moving slowly for the first 15 seconds of a match, I think it's much much more likely that there was a programming error in your autonomous mode that was causing some of your motors to fight each other and put a large load on the battery. Autonomous mode IS 15 seconds long, after all. |
#14
No, it was 15 seconds of teleoperated period (sorry for being unclear) and we'd literally see the OI Voltage Indictor go from 7 on up to 9, then trickle up to 12. It was wierd and unexplicable by everyone except our team lead, who said it was because we placed the batteries on concrete. We stopped putting the batteries on the ground, and the wierdness stopped happening. Who knows. |
#15
| Unknown Device ID(0) | DavidGitz | Control System | 13 | 28-01-2008 20:28 |
| SERIOUS COMPRESSOR PROBLEM | simeon1770 | Pneumatics | 6 | 18-02-2007 21:07 |
| FIRST Unknown | irishninja | General Forum | 4 | 24-04-2006 08:45 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
