Re: Relay program?
do a printf of x. You may not be getting the PWM value you think you are.
We have had problems with pwmXX values not being available in all of our subroutines. If that is working, try a nested if-not as elegant, but it works. Lastly try increasing the band you are allowing on 127-your offset may be off or you go through it too fast. Check that your value to the relay routine call is a logical 0 or 1 (try forcing it) |
| Instance relay | Team_486 | Programming | 0 | 28-03-2007 09:56 |
| Relay Commands | Matt Krass | Programming | 6 | 18-02-2006 23:03 |
| Relay Assignments | MulletFish | Programming | 9 | 27-01-2005 14:15 |
| Relay fault | archiver | 2000 | 2 | 23-06-2002 23:36 |
| Relay Outputs | OddOne | Technical Discussion | 3 | 01-02-2002 19:52 |
