Go to Post Mentors can always use mentoring. - JaneYoung [more]
Unread 29-01-2008, 17:32
SuspectZero's Avatar
SuspectZero SuspectZero is offline
2254 Team President
FRC #2254 (Twisted Transistors)
SuspectZero is an unknown quantity at this point
Wiring A Dipswitch
well i was trying to put a dipswitch into one of the Digital Inputs but i cant seem to get a signal from it. its a basic switch (open and close) and i have ground connected to the lower pin (in which case the switch is open) and i have signal connected to the other pin (in which case the switch is closed) but a closed switch does not seem to send a signal to the robot controller. any ideas?
Team 2254: Twisted Transistors
2007 FRC: Placed 18th in Regionals
2008 FRC: TBD
Unread 29-01-2008, 18:02
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Re: Wiring A Dipswitch
Suggest making sure your programmer has enabled the +5 V pull-ups on the inputs.
Unread 29-01-2008, 18:09
2254 Team President
i'm sorry what do you mean by +5V pull-ups?
2008 FRC: TBD
Unread 29-01-2008, 18:33
Make sure your dip switch is connected to digital in/out pins. For the Digital In/Out ports on the RC, your user code must define whether the port pin is an input or an output. By defining the port pin as an input, there is a resistor allowing a small amount of current (large resistance) connected from that input pin to the +5 V supply built into the RC (the "weak pulll-up"). Your dipswitch is connected such that if the switch is open, the RC should read a logic "1", and conversely, a logic "0" when the switch is closed. On the IFIRobotics site, there is a manual on the RC which provides more information.
Unread 29-01-2008, 21:15
If you're talking about the digital inputs on the Robot Controller, a switch connected between signal and ground is exactly the right way to do it. An open switch will be read as 1, and a closed switch will be read as 0.
How are you determining that no signal is being sent?
Unread 29-01-2008, 21:46
DonRotolo's Avatar
Back to humble
FRC #0832
To emphasize what MCahoon wrote: These pins can be inuts or outputs (you have to say which) - obviously, if #1 is configured as an output your RC will have a tough time reading the switch value...
(I know this from experience)
Don
expandable wiring Calvin_1631 Electrical 15 19-02-2007 07:33
wiring? SPARKY1688 Electrical 4 31-01-2005 17:44
wiring Michael Leicht Inventor 2 21-01-2005 15:49
pneumatic wiring nick_champ_2 Electrical 0 17-02-2003 18:28
wiring. archiver 2001 1 24-06-2002 00:07
