Go to Post The Questions is, do we attempt to build a Mr.Fusion, or do we go for the Plutonium from the Libyans? - dag0620 [more]
Unread 28-01-2008, 18:08
chattycat14's Avatar
chattycat14 chattycat14 is offline
AKA: Jessica
FRC #1228 (Rahway Highschool Indians)
chattycat14 is an unknown quantity at this point
Send a message via AIM to chattycat14
Re: Wiring the IR Receiver
We're having a problem, we get a response from the IR board saying that the digital input has a value of 1 when it should be a 0. What should we do?
<3 Jess
Unread 28-01-2008, 18:32
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
Make sure you are using either the 12 volt robot battery or the digital input power pins (which use the robot battery), otherwise the signal is not being grounded properly.
Old stuff:
FRC 2007 Strategy Solver. Version: 2.55. Progress: done.
Unread 28-01-2008, 18:37
AKA: Jessica
Under the online window it changes from 0 to 1 when the button is pressed, but when the actual program is downloaded it retains the value of 1.
<3 Jess
Unread 28-01-2008, 22:09
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Online window??? Anyway, here is the code we're using. It has some safety built in, and shows the state on the OI.
//Variables should be declared at the beginning at the program
int mode = 0; //Set it to zero so the robot won't move!
int modea;
int irerror;
int errorloop;
//Switches off all the LEDs on the OI
Switch1_LED = 0;
Switch2_LED = 0;
Switch3_LED = 0;
Relay1_red = 0;
Relay2_red = 0;
Relay1_green = 0;
Relay2_green = 0;
Pwm1_green = 0;
Pwm2_green = 0;
Pwm1_red = 0;
Pwm2_red = 0;
/*The following code will check to make sure the IR sensor is not malfunctioning,
or it is not disconnected, as no more than one button can be triggered at a time.*/
mode = 0; //If there is no signal from the IR board later in the code, then disable the robot
irerror = 1;
if ((rc_dig_in03 + rc_dig_in04 + rc_dig_in05 + rc_dig_in06) < 3)
	irerror = 0; //Tells the disable program that there is no error detected
	if (rc_dig_in03 == 1)
		modea = 1;	//Set to Mode 1 (1st button)
	if (rc_dig_in04 == 1)
		modea = 2;	//Set to Mode 2 (2nd button)
	if (rc_dig_in05 == 1)
		modea = 3;	//Set to Mode 3 (3rd button)
	if (rc_dig_in06 == 1)
		modea = 0;	//EMERGENCY STOP (4th button)
	mode = modea;
//The following are the certain autonomous programs
//Each mode acts like a different program.
if (mode == 1) //Mode 1
	printf("Mode 1 %d\r");
	Switch1_LED = 1;
//Put your custom programming here, this will execute when the first button is pressed
if (mode == 2) //Mode 2
	printf("Mode 2 %d\r");
	Switch2_LED = 1;
//Put your custom programming here, this will execute when the second button is pressed
if (mode == 3) //Mode 3
	printf("Mode 3 %d\r");
	Switch3_LED = 1;
//Put your custom programming here, this will execute when the third button is pressed
//Leave the following code at the very end of the autonomous cycle, so it is sure to execute when and if it is needed.
if (mode == 0) //EMERGENCY STOP
	printf("Mode: Disabled %d\r");
	pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  	pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
	relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
	relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
	relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
	relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
	//The following code shows all the red lights
	//on the OI to tell the drivers that the autonomous
	//has been disabled
	Pwm1_red = 1;
	Pwm2_red = 1;
	Relay1_red = 1;
	Relay2_red = 1;
	if (irerror == 1) //If the IR has an error, then flash
		printf("IR Sensor Problem, Check connection %d\r");
		errorloop++;
		if (errorloop > 5)
			Pwm1_red = 0;
			Pwm2_red = 0;
			Relay1_red = 0;
			Relay2_red = 0;
		if (errorloop > 9)
			errorloop = 0;
I think I took all of our personal, never to be seen code out, and I think I have all the variables declared in the beginning. I give the right for any team to use this, and I give no warranty. If it does not work, you can PM me, and I can try to help. I will not help with any of your personal programming though.
PS: We have tried this on our robot, and it works great! So I encourage any teams that aren't very programming savvy to try to use this to at least do something.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 29-01-2008, 18:42
AKA: Jessica
hey,
we have easy c, so if anyone could help then it would be appreciated.
<3 Jess
Making the IR receiver Omni Directional Spylake Technical Discussion 0 08-01-2008 13:00
Using the IR Receiver on the Robot LG67 Control System 1 06-01-2008 01:42
GPS receiver John Gutmann Technical Discussion 23 01-03-2007 02:35
IR Receiver zachriggle Electrical 7 09-02-2006 17:11
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
