Go to Post The stated goals of FIRST are to inspire a culture that values science and technology. Inspiration needs Motivation. What motivates people? Competition. - Dmentor [more]
Unread 29-01-2008, 18:46
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
145 + Glue =awesome?
Our frame now is tougher then Chuck Norris. All thanks to Mr. Epoxy who is married to Mrs. Rivets.
I would like to thank Mr. Wolf and Norwich Glass for doing this for us. Oh and the mentor who to the pics, I'm not sure who it is =P.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 29-01-2008, 18:50
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: 145 + Glue =awesome?
Looks great ... but it looks awfully low. Do you have enough clearence for the center structure supports?
___________________
- Tennyson, Ulysses
Unread 29-01-2008, 18:58
That guy
AKA: Dennis
we sure hope so, i have seen bots a lot lower then that.
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Way to not do it yourself... you better hope you dont have to change anything... and thats not really going to make your robot any stronger,it will still flex as much as if it was bolted together, you just wont be able to take it apart now... have fun!
Unread 29-01-2008, 19:06
That guy
AKA: Dennis
Mr. Wolf is a mentor and Norwich Glass is a sponsor of our team. That is the only thing that was not done out of our shop. Some teams have everything fabbed at a shop then all the team does is put it together.
The weak spots on a frame are it's corners, make them stronger then the frame as a whole will be.
The drive train has been tested, our lift fits on it great, and everything is just right. So there shouldn't be a need to take it a part.
Unread 29-01-2008, 19:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I must be missing something here. Why are you using black goo to join your frame members as opposed to something such as say, bolts? What is that stuff anyhow?
Unread 29-01-2008, 19:14
FRC #2952
Well those teams suck and they should be kicked out, not that they could enforce that... and the corners are not the weakest spot they have 2 to 3 layers of metal unlike the sides which are long and only 1 layer, unless you varied from the default layout a lot.... i sure hope your right when you say it fits cause it would really suck if you had to take it apart...
Unread 29-01-2008, 19:20
FRC #2952
ummmm welll according to the last 5 or so posts its epoxy (glue)
Unread 29-01-2008, 19:22
That guy
AKA: Dennis
It's epoxy, we are saving a good amount of weight, by not using as many.
Bolts can losen during a match and need to be tightened. That makes the frame corners weaker. Epoxy can't losen, so it will make the frame strong all the time. Welding will do the same thing, but welding can make the frame warp. This is just as light weight as welding, but with no warping.
Unread 29-01-2008, 19:28
FRC #2952
if you tighten bolts theyll be fine, depending on how much stress you put on the frame epoxy will crack, it usually shatters like glass only with a lot of stress though, im sure the epoxy will work fine it will just suck ifi you make any mistakes
Unread 29-01-2008, 19:47
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Welcome to ChiefDelphi. Helpful or inquisitive posts are encouraged here, but whining, complaining or making derogatory remarks about other people or teams is not.
Keep that in mind as you explore the wealth of information that's available here. Not only do other students see what you write, but mentors, sponsors and FIRST personnel as well. Do unto others and all that.
--Madison--
...down at the Ozdust!
Unread 29-01-2008, 20:47
FRC #2952
i only make remarks at the teams that have there robot fabricated by someone else(that to me is cheating and defeats the whole purpose of this team activity) , i was trying to figure out why this team would use epoxy when bolts are readily available, then when the team said why i explained the epoxy does break and that properly tightened bolts should not come lose. i'm not being mean, i'm being curious and realistic
Unread 29-01-2008, 21:01
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Congratulations on finding a successful fusion of students and engineers that works for your team. It sounds like your team understands the purpose of FIRST far better than teams whose students never touch the robot, or than teams who try to attack this problem with no engineer support at all. Best of luck with the rest of your season.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 29-01-2008, 21:07
x7shaddow's Avatar
x7shaddow x7shaddow is offline
master of sleep
FRC #1346
x7shaddow is an unknown quantity at this point
I'm curious as to why you don't get your frame welded, it's stronger then epoxy and bolts togther, you dont have any bolts to lose, and you wouldn't believe how much weight you'd save not using bolts. Becides if you're sure enough of your frame design to epoxy it togther you'd be sure enough to weld it, because grinding off the weldded joints would probabally be a compareable ammount of work to that of removing all that epoxy.
Unread 29-01-2008, 21:30
in between teams
AKA: Luke Van Oort
Surprisingly, welding may not be that much stronger than epoxy (if stronger at all). Welding ruins the heat-treatment on the aluminum, which makes its strength take a nosedive. On the other hand, some epoxies are insanely strong and do not affect the heat treatment.
Team 1219: 2009 - Mentor
TRX 145 Xmas party DarkFlame145 Chit-Chat 1 11-01-2008 10:39
CD's Unofficial Caption Contest #145 Billfred Games/Trivia 31 22-04-2007 20:45
Glue? IMac Technical Discussion 10 25-03-2007 16:10
No glue... :( hayakuneko General Forum 17 03-02-2006 16:00
glue Greg Perkins Chit-Chat 5 06-03-2003 12:40
