Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 29-01-2008, 19:42
Gherkinman's Avatar
Gherkinman Gherkinman is offline
Native German Pickle
AKA: Odin All Father
no team (Thor)
Rookie Year: 1342
Gherkinman is an unknown quantity at this point
Send a message via AIM to Gherkinman
Assembly Stress Analysis
I know it is possible to construct a stress analysis on a single .ipt, but it would be extremely useful if inventor provided the capability to conduct a stress analysis on an entire .iam. Does anybody know if it is even possible to do this and if so can you please post how?
Unread 29-01-2008, 19:47
grsnovi's Avatar
grsnovi grsnovi is offline
Autodesk Inventor Team - Portland,
AKA: Gary R Smith
FRC #2542
grsnovi will become famous soon enough
Re: Assembly Stress Analysis
Inventor does not currently do stress analysis of assemblies (it is planned for a future release). You can however derive your assembly into a single part and then analyze the part. This may or may not be useful depending on the complexity of your assembly and how close you need to analyze the stress.
Unread 31-01-2008, 23:41
Gherkinman's Avatar
no team (Thor)
Rookie Year: 1342
How exactly does one derive an assembly down to a single component. I tried googling it but no luck. This sounds like a useful technique in more than one way and I would very much like to be able to utilize it.
Unread 01-02-2008, 09:31
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Start a new part (ipt) file.
Exit sketch.
Click Derived Component.
Select the assembly (iam) file.
+ for all parts you want combined.
This might give you some information for a rigid assembly derived as a single part. If you are interested in the FEA of a moving part within it's range of motion in the assembly check out Applications>Dynamic Simulation. You can assign Gravity and other forces and then output a series of time-steps for FEA analysis.
Have your teacher check with the Inventor reseller for your area and perhaps he can get you the free Autodesk Official Training Curriculum for Dynamic Simulation and FEA pdf file for Inventor 11. There were changes to the interface for r2008 but between that "book" and the tutorials in r2008 you might be able to learn some useful stuff. If your teacher has a budget you could order the new AOTC book from http://estore.autodesk.com
This is fairly complex stuff - really impressive if you can demonstrate some results. If you run into trouble post what you have and you might be able to get some help.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
254/968 Gearbox Assembly Time Study/Analysis Travis Covington Technical Discussion 8 08-05-2007 13:40
pic: FEA - Stress Analysis of Frame Rail kramarczyk Extra Discussion 5 01-02-2007 16:29
Stress StephLee General Forum 48 24-01-2006 00:25
Driver Stress? dddriveman General Forum 55 16-03-2005 23:44
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
