Go to Post When was the last time you heard of someone on their death bed talking about a great movie they saw? I think it far more likely to hear of their accomplishments, something they did to make things better. Well that's what FIRST is all about. - DougHogg [more]
Unread 29-01-2008, 20:41
darkpheonix darkpheonix is offline
FRC #2225
darkpheonix is an unknown quantity at this point
Cool What 4 functions are you using for autonomous mode?
Hey,
I'm just wondering what teams are using for the 4 functions of the autonomous mode. Right now, we're deciding whether to use pre-programmed functions or just controlling it like a normal contoller. What are your guys thoughts?
Unread 29-01-2008, 20:42
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: What 4 functions are you using for autonomous mode?
Originally Posted by darkpheonix View Post
Hey,
selecting between 4 different auto modes.... (pending on where the ball is)
TJB2225 TJB2225 is offline
TJB_2225
AKA: Trenton
FRC #2225
TJB2225 is an unknown quantity at this point
Ummmm im not sure what my team is doing but i'll check in on it.
Unread 29-01-2008, 20:47
seven11mafia seven11mafia is offline
FRC #2225
seven11mafia is an unknown quantity at this point
is anyone using simple 4-way directional controls? is this a good/bad idea? what are the advantages/disadvantages?
Unread 29-01-2008, 20:59
joshyboy9987 joshyboy9987 is offline
FRC #0706
joshyboy9987 is an unknown quantity at this point
I think the control will be extremely hard using just 4 directions, because you'll have a hard time getting a signal to your robot. (With all the other IR signals & with the distance and stuff) I think we are going to do the position of the balls thing.. Otherwise it's just going to be a normal autonomous mode.
I was thinking though, what are some suggestions for sensors to tell where you are on the field? We tried the accelerometer & that didn't work, even with a bunch of filters and some tricky software stuff... Now I'm thinking ultrasonics, cuz that would help with navigating the course too. Then there's the obvious encoders, but there's gotta be a better way, right?
Unread 29-01-2008, 21:02
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I'm going to advise against attempting to have your robocoach try to drive the robot because of the potential interference issues. Here's the ongoing discussion of why: http://www.chiefdelphi.com/forums/sh...ad.php?t=62775
Unread 29-01-2008, 21:11
x7shaddow's Avatar
x7shaddow x7shaddow is offline
master of sleep
FRC #1346
x7shaddow is an unknown quantity at this point
I tried to suggest that function 1-4 each access option menu 1-4 with each having 4 functions, but apparently that would be illegal.
Unread 29-01-2008, 21:48
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
We're just doing a forward, left, right, stop, thing.(and maybe a lift-the-arm command)
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 29-01-2008, 23:38
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
For now, due to fairly high rates of uselessness of the IR reciever board in multi-remote environments, nothing, nothing, nothing and nothing. Fully autonomous right now (with adaptive ultrasonic cruise control ).
I'll write the IR into the robot in case it becomes viable (point wise) to knock the ball off. But since making half a lap in autonomous is worth the same as the ball....
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
What drivetrain style are you using? Mike Nawrot General Forum 32 27-01-2008 16:32
How should we call camera tracking functions during autonomous mode? SHerpich Programming 1 15-02-2006 18:33
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
What do you do during autonomous mode? Salik Syed Programming 46 21-03-2004 21:05
What type of autonomous mode program are you using? SilverStar Programming 1 21-01-2004 18:48
