Go to Post If the GDC can actually top Rebound Rumble, I might cry at the reveal. - PayneTrain [more]
Unread 29-01-2008, 18:42
greatman05 greatman05 is offline
AKA: Chavez Clemons Jr.
FRC #2224 (Phoenix Phenoms)
greatman05 is an unknown quantity at this point
Send a message via AIM to greatman05 Send a message via MSN to greatman05 Send a message via Yahoo to greatman05
Lightbulb Joystick Programming
Hello. Does the FRC default code allow 2 joysticks to be used? Also, is there any way to adjust the sensitivity of the controllers, or the speed of the motors?
Unread 29-01-2008, 18:50
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Re: Joystick Programming
Hi, and yes there is. The controllers (I'm going to guess that you mean the Victors) are pretty much un-programmable. The motors, however, are programmable by way of the Victors that run them. Now I'm not sure what you are using for the programming tool but we used the free ROBOTC software that can be downloaded from one of these forums(try searching FREE ROBOTC, that's what I did). Let me know if it's a different programming language and I'll help you. You could also PM me if you need any more help.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 29-01-2008, 19:13
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
also, if you're new at this and dont have anyone else who knows what they're doing, avoid using MPLab....try EasyC or robotC instead. i dont have any experience with these, but they're supposed to be easier!
Unread 29-01-2008, 19:59
MiniNerd24's Avatar
I concur ROBOTC and EasyC are probably the easiest.
The system is down.
Unread 29-01-2008, 20:00
tseres's Avatar
i just avoid them because they have 'easy' in them (well, just easyC)
Unread 29-01-2008, 21:05
I'm sorry, I should have been a bit clearer: By controllers, I meant the joysticks.
Where in the code does it allow you to adjust motor sensitivity? Looking at the default code, I have no idea where I can adjust that.
Unread 29-01-2008, 21:11
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
if you look in the default code you will see lines like
pwm01 = p1_y
pwm02 = p2_y
pwm is the term for each of the moters. p1_y and p2_y are joystick 1 & 2 on the y axis. These give you a value between 0 and 255, with 127 being neutral. To adjust the sensitivity you can take the joystick input and apply a little bit of math and what you set the motors to will be less.
I will give you a link to a thread I posted in a couple of weeks ago on this.
Edit: http://www.chiefdelphi.com/forums/sh...ad.php?t=61929
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 29-01-2008, 21:45
MiniNerd24's Avatar
I'm sorry what programming tool are you using? That code that wt200999 posted may be the code that works for EasyC only (i don't know really). There are other codes that work with other systems.
The system is down.
Unread 29-01-2008, 22:29
wt200999's Avatar
Texas Instruments
AKA: Will Toth
Sorry about any confusion, that thread was about how to do it in easyC, the example I posted in there I wrote in MPlab. Someone else had posted code in that thread that works in easyC if you are using that.
Unread 30-01-2008, 18:33
OK...thanks for the info.
I have another question: What kind of algorithm or math should I use to reduce joystick sensitivity? I am really new to this programming thing...
Unread 30-01-2008, 20:28
timville's Avatar
timville timville is offline
AKA: Timothy Friez
FRC #1185 (X-Bots)
timville is an unknown quantity at this point
Send a message via AIM to timville
Hi there.
ROBOTC makes using the joystick very easy. If you wanted to use the joysticks to drive your robot you could the following code:
while(true){
motor[port1] = frcRF[p1_y]; //maps pwm port 1 to the Y axis of Joy1
motor[port2] = frcRF[p2_y]; //maps pwm port 2 to the Y axis of Joy2
You can in exchange slow down the motors and still retain the joystick "movement" by dividing the values you're getting from the joystick... like in this example:
while(true){
motor[port1] = (frcRF[p1_y] / 2); //maps pwm port 1 to half the value of the Y axis of Joy1
motor[port2] = (frcRF[p2_y] / 2); //maps pwm port 2 to half the value of the Y axis of Joy2
2003 - Rookie All-Stars Awards - #1185 (Pittsburgh)
2004-2008 FIRST Volunteer - Ref/Head Ref (Pittsburgh)
2002-2007 FIRST Lego League Volunteer - Head Ref (Pittsburgh)
Unread 30-01-2008, 20:40
in between teams
AKA: Luke Van Oort
I posted here about what we do. It gives us maximum speed (something dividing doesn't) and reduces sensitivity at low speeds. If you are using RobotC or EasyC, I don't know how you would implement it, but I assume that it is possible (I mean, if those tools don't allow working with arrays, I would be very disappointed).
Team 1219: 2009 - Mentor
Joystick Programming LieAfterLie Programming 7 15-02-2007 09:30
Programming a Joystick sbf2009 Programming 3 10-02-2007 15:59
Joystick Programming team 803 Programming 6 21-02-2006 11:49
Joystick Button programming Bharat Nain Programming 5 18-02-2005 11:48
single joystick programming Bill Bonsky OCCRA 2 04-10-2003 09:47
