Bearing Blocks
Our team is using the Andy Mark Supershifters with the 2'' longer shafts. Where would be a good place to buy bearing blocks for them? Or is it better to make our own?
Re: Bearing Blocks
You can buy pillow blocks (bearing blocks) with bearings in them from mcmaster-carr. (www.mcmaster.com)
Re: Bearing Blocks
we ended up making bearing blocks for our mechanum drive last year, and they turned out good, but unless you have people who are good at welding and machining you might want to consider buying some.
Re: Bearing Blocks
we got some amazing plastic ones from mcmaster for about the same cost as metal ones but the weight like 5oz each and this is for 3/4" shaft
Re: Bearing Blocks
Thank you all the help. We ordered some from McMaster-Carr.
| Power Distribution Blocks, buying? | 1596guy | Kit & Additional Hardware | 9 | 22-02-2007 18:21 |
| Terminal Blocks in Kit of Parts? | Mark Pierce | Electrical | 13 | 24-01-2007 00:37 |
| pic: Shaft Drive Bearing Blocks | MAteo9944 | Extra Discussion | 25 | 01-01-2007 11:22 |
| [OCCRA]: Pillow Blocks? | Fizzix | OCCRA Q&A | 1 | 12-10-2004 20:57 |
| pillow blocks | Jacqui Sutton | Kit & Additional Hardware | 1 | 11-01-2003 10:43 |
