Go to Post What is this "non-robotics life" of which you speak? :ahh: - Karibou [more]
Unread 29-01-2008, 17:50
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Bearing Blocks
Our team is using the Andy Mark Supershifters with the 2'' longer shafts. Where would be a good place to buy bearing blocks for them? Or is it better to make our own?
Unread 29-01-2008, 21:11
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Bearing Blocks
You can buy pillow blocks (bearing blocks) with bearings in them from mcmaster-carr. (www.mcmaster.com)
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2008, 21:17
x7shaddow's Avatar
x7shaddow x7shaddow is offline
master of sleep
FRC #1346
x7shaddow is an unknown quantity at this point
Re: Bearing Blocks
we ended up making bearing blocks for our mechanum drive last year, and they turned out good, but unless you have people who are good at welding and machining you might want to consider buying some.
Unread 29-01-2008, 21:50
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Bearing Blocks
we got some amazing plastic ones from mcmaster for about the same cost as metal ones but the weight like 5oz each and this is for 3/4" shaft
-Dustin Benedict
Unread 29-01-2008, 22:30
Team Role: Driver
Re: Bearing Blocks
Thank you all the help. We ordered some from McMaster-Carr.
Power Distribution Blocks, buying? 1596guy Kit & Additional Hardware 9 22-02-2007 18:21
Terminal Blocks in Kit of Parts? Mark Pierce Electrical 13 24-01-2007 00:37
pic: Shaft Drive Bearing Blocks MAteo9944 Extra Discussion 25 01-01-2007 11:22
[OCCRA]: Pillow Blocks? Fizzix OCCRA Q&A 1 12-10-2004 20:57
pillow blocks Jacqui Sutton Kit & Additional Hardware 1 11-01-2003 10:43
