Go to Post Thank you from the bottom of our IFI controllers, The Robonauts. - Natchez [more]
Unread 29-01-2008, 22:54
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
1/2" bump in field?
Has anyone figured out why the bump in the field is stated as being 1/2"? We built our chassis and have got the clearance to be about 5/8" which is cutting it close to this bump. However the more we investigate the cause of the bump, it seems it shouldn't be that much. In the field specs there is the support plate for the lane divider which is 3/16" thick, protrudes 2 feet into the lanes, and I assume it is placed underneath the carpet. When we place a 1/4" plate under our carpet the bump is very slight and nowhere near 1/2". Anyone else with a low rider bot chassis thinking about this too?
Unread 29-01-2008, 22:58
Re: 1/2" bump in field?
It's on top of the carpet, covered by carpet. You're right, it might not be that much. Still, it will affect gameplay.
Unread 29-01-2008, 23:01
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Oh wow I hope this isn't true. Our robot IS 1/2" off the ground!!!
Where is this written, how did I miss it?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 30-01-2008, 00:18
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Section 6.2.3 of The Manual, in the section describing the Lane Divider:
The LANE DIVIDER is attached to vertical posts that are anchored to supporting plates covered by carpet. Note that these plates will create a bump in the carpet approximately 1/2 inch tall, and as a result the surface of the TRACK will not be perfectly flat.
EricH is correct, the bumps are caused by the supporting plates being placed on top of the baseline carpet, and then covered with additional pieces of carpet that are then taped down to the field carpet. So the 1/2 estimate is a reasonable one (and then when you throw in the general statement at the beginning of Section 6: "the arenas are assembled in different venues by different event staff, small some variations do occur. Fit and tolerance on large assemblies are ensured only to within 1/4 inch. Successful teams will design robots that are insensitive to these small variations." things could start to get very interesting if you are only designing a robot with 1/2 inch ground clearance).
-dave
Unread 30-01-2008, 06:58
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
I've seen some team pictures with 3/8" clearance. If one team is doing, there must be others. I'm worried about some of these teams that aren't reading the rules that closely.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 30-01-2008, 06:59
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
See also this thread with Kickoff pictures by Elgin Clock. And it is multiple bumps, not just a single one.
Unread 30-01-2008, 09:17
Brandon Holley's Avatar
I was at kickoff at manchester and the bump there was ~1/2". However it is located in an area on the field where it would be impossible to "straddle" it. Meaning you wont be able to get your right side/left side wheels on opposite sides of it. This means that you will get a set of wheels over it which should make it a non issue.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 30-01-2008, 11:29
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
For our team, we didn't catch this tell we went up to another teams shop to use their mills and one of their mentors pointed it out us. Luckily I didn't know how easy it was for the build team to drop the wheels down some, so like the next day it was fixed clearing something like 3/4"(before it was like 1/4").
Unread 30-01-2008, 12:41
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Also, don't forget. It's not just your chassis that needs to be able to clear this, it's also your manipulator. It'll be interesting to see if some of those fork lift devices get hung up on the support plates.
___________________
- Tennyson, Ulysses
question on "bump" gondorf General Forum 8 24-01-2008 12:03
Line or Bump? Swathi General Forum 2 05-01-2008 16:08
"waiting for bump switch to be hit"???? Punjabguy87 Programming 10 19-02-2005 12:18
"arena field switches" reilly General Forum 5 18-01-2005 00:30
Need 40" Square Field Carpet Yan Wang Regional Competitions 0 24-03-2003 21:32
