Go to Post We use the engines of our imagination on the robot all the time. FIRST being an engine of change after all. - Mark McLeod [more]
Unread 29-01-2008, 23:02
DPTeam270Driver's Avatar
DPTeam270Driver DPTeam270Driver is offline
Deer Park Driver
FRC #0270 (Falcon X)
Team Role: Driver
DPTeam270Driver will become famous soon enoughDPTeam270Driver will become famous soon enough
Exclamation HELP!!!!! Taigene motor load
srry if this was already discussed, but its kinda urgent.
we just started to test our arm and claw, but the Taigene motor doesnt hold the wieght. the motor doesnt lock and is slipping. is there away to program the speed controler to have it lock or something we did wrong w/ the motor.
can anyone tell me how to fix it or is this supposed to happen???
is anyone else having the same problem???
(just our wrist is about 6lbs)
if anyone can help plz hurry
we NEED this done b/c our program mentor is comin and we need a complete robot
-team 270
Unread 29-01-2008, 23:15
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: HELP!!!!! Taigene motor load
We had the same problem. You would hope that the worm gear would keep it from backdriving, but it doesn't. So we went with the Keyang instead. Programming won't help "lock" it. You are talking about running the motor at a stall (just enough voltage to stop the movement), which is never a good idea. Think about a design mod to solve your problem. Teams in the past with this sort of problem have added in a locking mechanism (like a brake). Or you can try the Keyang motors, they don't backdrive.
Good luck!
Unread 30-01-2008, 00:02
JimWright949's Avatar
JimWright949 JimWright949 is offline
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
Have you tried to put your Victor into Brake mode? The doc:
http://www.ifirobotics.com/docs/ifi-...al-9-25-06.pdf
should help you with this.
-Jim
PS Fans! Use lots of fans on this Victor and motor!
Unread 30-01-2008, 00:16
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
we ran into this problem....its messy to try and create a brake..change the motor...we went through 3 different prototypes..the first with a fisher price and the other with the taigene motor and the third with a taigene motor and a brake....the arm just got too heavy
Unread 30-01-2008, 00:30
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Just for the sake of clarity, remember that while using Brake mode will cause your motors to slow down more abruptly, it will not prevent your motor from backdriving. If you want to prevent backdrive, you'll either need to add an encoder and control it in software, add a mechanical brake, or use a motor with a worm gear (such as the Denso).
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 30-01-2008, 00:42
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
last year our arm back drove sometimes and when it was on brake it completely stopped back drving....
Unread 30-01-2008, 02:44
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
we are familiar with your problem since we encountered the same problem about a week and a half ago. The taigene worm gear inside is all plastic and fine, thus unable to hold in place.
Our solution was two-fold. We used a larger gear ratio to pivot our arm and used springs and frame stop points to smooth the flow.
The main thing is design. Our design eliminates the problem of whether the arm can move or not once a load is present. It doesnt matter for our robot.
The same thing will happen with the window motor, however a double step reduction eliminated any arm movement problems on our second joint. The double reduction eliminated the need for such a huge sprocket at the top of our arm joint, keeping us within design dimensions.
Unread 30-01-2008, 22:30
Deer Park Driver
Team Role: Driver
Talking Re: HELP!!!!! Taigene motor load
Thank you to those of you who suggested things
team 270 appreciates the help
- team 270
Unread 09-02-2008, 18:43
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
just a note*
there is an Allen screw on the side of the motor and when you tighten the screw it will keep it from falling.
we have ran into some issues with the plastic teeth in the inside of the motor braking off. up to 5-10 teeth in a row. we had all the specs looked up and planned out and we did the calculations to only find that we are only using 60% of each motor (on on each side of our arm mechanism)
if any other teams have experienced this problem and have a solution and would share that would be greatly appreciated, if you could, please PM me your reply.
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 09-02-2008, 18:49
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Does anyone have any estimates on how much load it takes for this to occur? We were planning on using the taigene motor for our elevator (haven't run the whole thing yet) with a 4" spool to reel in the cable. How much weight do you think this will support before backdriving?
Unread 09-02-2008, 21:14
Mark Holschuh's Avatar
Mark Holschuh Mark Holschuh is offline
FRC #2194 (Fondy Fire)
Mark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud ofMark Holschuh has much to be proud of
We are also using the Taigene motor to operate our lift and also noticed that it slips when we try to hold with the the trackball up. Does anyone know how much load it takes to start failing the plastic teeth?
"The true sign of intelligence is not knowledge but imagination."
-- Albert Einstein,
"The ultimate test of man's conscience may be his willingness to sacrifice something today for future generations whose words of thanks will not be heard."
- - William Proxmire
Unread 09-02-2008, 21:18
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
what kind of reduction are you using?? cause I'm sure it will help, we are about to test tomorrow if our arm can lift the ball up and we have a double stage reduction of about 4:1 and it can carry a 10 pound weight pretty easily
I don't have any numbers for you, but I'm pretty sure reductions can fix any problems you might be having!!
Unread 09-02-2008, 22:18
Andrew Nabors
AKA: Andrew Nabors
we wern't even lifting the ball and we have two motors on each side of the ball, calculated to be working at about 60% of what they could and they blew in no time for us, moved up and down about 5 times and you can just hear when the teeth of the plastic gears pop off.
i will try to get our gear specs and what not to share with everyone, for now here are some pictures.
Unread 09-02-2008, 22:25
FRC #1360
are we even allowed two of those motors?? maybe they worked against eachother??? cause we haven't had a problem with ours yet and we are only using one motor. can you show whats on the end of your arm (weight wise and leverage)
Unread 09-02-2008, 22:32
Andrew Nabors
AKA: Andrew Nabors
i havnt read anything saying we cant, but if anyone says that we cant, please send me a rule number so that i can look into it.
sorry thats all i have right now..
anyways the whole arm structure from where it mounts to the base (including motors, shafts, and gears) weighs 40lbs.
Taigene Window Motor Information CoupeSprinter Motors 4 29-01-2008 20:27
taigene motor shaft wildabyss Technical Discussion 3 24-01-2008 17:11
Taigene Window Motor Specs master_nickz General Forum 0 22-01-2008 15:53
Taigene Motor Specs Guy_E Motors 7 21-01-2008 03:25
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
