Go to Post Now, FIRST has taken over my life (and my harddrive)! - Kate00 [more]
Unread 29-01-2008, 23:38
Re: IR_Sensor Programming
What Will said.
That code plays a little trick with the digital inputs and combines the four (0 or 1) inputs into a single four-digit binary number, where each digit represents one of the four digital inputs.
So the numbers you get are:
binary  decimal
0000      0
0001      1
0010      2
0100      4
1000      8
If you get any other number it means the digital inputs aren't connected correctly. For instance, if the IR board isn't connected at all you will get
binary  digital
1111     15
So that can help you to debug bad connections and see it on your OI display.
P.S. When you first use the OI Select button to switch to User Mode you'll see "u015" or something similar displayed for a couple of seconds. This is the Master Code version loaded on the Robot Controller.
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
programming great_one411 Programming 2 15-02-2003 08:59
programming great_one411 General Forum 1 14-02-2003 11:28
Programming archiver 2000 1 23-06-2002 22:34
