Go to Post Unlike robot design, in the clothing world there's no such thing as too much pocketing - Jaci [more]
  #31   Spotlight this post!
Unread 29-01-2008, 00:38
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
Re: 1726 Prototype Testing
kinda looks like what where going with. great job.
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
  #32   Spotlight this post!
Unread 29-01-2008, 01:07
Frank Neuperger Frank Neuperger is offline
FRC #0842
Frank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to behold
Nice job. It appears that the ball develops a rearward spin with this design as it rolls off the catapult forks. This is elegant. It seemed to roll back towards the bot after the shot.
The mechanism illustration suggests an "over center" latching scheme where actuators initially pressurize with the force vector of the actuators aimed just below center of the mechnism fulcrum. As such it will not fire unless somthing bumps them above the fulcrum. Possibly the small gizmo at the far left of the illustration does this. Getting both actuators "over center" at the same time may be a challenge due to build tolerances and mechanism flex.
I wonder about the shot to shot repeatability in terms of height and trajectory. To be shooting on the move, the shot to shot repeatability would be important.
  #33   Spotlight this post!
Unread 29-01-2008, 01:21
team2061's Avatar
Gilberto Gonzalez
What makes the "ball pick up" device go foward and back
  #34   Spotlight this post!
Unread 29-01-2008, 01:28
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Actually, I'm just really bad at making drawings I believe this picture from our gallery demonstrates it best:
the point where the piston attaches is just above the line created by the front pivot point and the end of the flinging arm. When the cylinders are pressurized, the catapult "slowly" begins moving because of that slight height. The end pieces you see are just mechanical stops so the catapult arms are always under the point where the piston attaches.
As for the ball-picker-upper, we simply use a pneumatic piston right now, but may end up switching to a motor to conserve air for the catapult:
Last edited by TheOtherGuy : 29-01-2008 at 01:33. Reason: added links to larger images
  #35   Spotlight this post!
Unread 29-01-2008, 02:25
FRC #0842
Thanks of the clarification and the details. Your design is a real inspiration to others that are looking at catapults.
How is shot to shot repeatability in terms of height and trajectory?
Regards
Frank
  #36   Spotlight this post!
Unread 29-01-2008, 09:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We won't know how repeatable it is until we build the last part, which is an arm that sits on top of the ball to hold it down, and is raised when we want to fire the ball. The idea is to use the downward force of this arm plus the weight of the ball to overcome the initial vertical upward force of the catapult...and then when the top arm is released, the vertical force of the catpult is greater than the weight of the ball, so the ball fires. In our initial tests using my arm as the ball holder downer, this seems to work ok, but we need to do some fabrication soon (ie today) to get that arm built and on the robot, so we can answer your question more accurately
  #37   Spotlight this post!
Unread 29-01-2008, 22:36
x7shaddow's Avatar
x7shaddow x7shaddow is offline
master of sleep
FRC #1346
x7shaddow is an unknown quantity at this point
you're loader mechanism seems to work well but I'd hate to see what happens when you accidentally run into a wall at full speed
  #38   Spotlight this post!
Unread 29-01-2008, 23:40
MrForbes's Avatar
AKA: Jim
heh...we already know what happens when we do that! and so we're working on other ways to build it to take more abuse.
  #39   Spotlight this post!
Unread 29-01-2008, 23:47
Unregistered User
AKA: Kevin Forbes
Funny you should mention that! We were working on a design today for a collapsible ball picker-upper:
The 1/4" strip of lexan acts as a slight spring. It takes just the right amount of force to push it, and the aluminum bracket prevents the arm from swinging out.
We realized we need to design this after we (I) accidentally test-crashed the manipulator into a wall and it was almost mangled beyond repair (but not quite, because we did repair it)
  #40   Spotlight this post!
Unread 29-01-2008, 23:48
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Here is our version of your catapult!http://www.youtube.com/watch?v=LwmyQMlmaRY
Thanks for the help!
Faridodin "Fredi" Lajvardi KD7WKD
  #41   Spotlight this post!
Unread 29-01-2008, 23:55
MrForbes's Avatar
AKA: Jim
Nice! see, it's not so hard to do
  #42   Spotlight this post!
Unread 30-01-2008, 01:50
dtengineering's Avatar
AKA: Jason Brett
Different configurations are likely to work, too. We've prototyped one arm of our two armed launcher and achieved heights of about 5' at a 45 degree angle using just two 1.5x8" cylinders and one clippard tank of air at 60 psi. We are building the second arm (two more cylinders, one more tank) and expecting to clear about 8' with both working together. We'll post some video when we get that happening.
As for picking up the ball... just try smashing it into the wall. If your front end is low the ball shoots up, and you drive right underneath it as it falls back down.
Not particularly elegant, and not much good in the open field, but I'm not quite sure how anyone is going to get a ball to sit still on the open field for them to grab anyways. Mind you, I may be wrong about that... I haven't played this game before, you see...
Jason
  #43   Spotlight this post!
Unread 30-01-2008, 01:51
Unregistered User
AKA: Kevin Forbes
actually, we have an automated system for picking up the ball that appears to work quite nicely All we have to do is run into it...
  #44   Spotlight this post!
Unread 30-01-2008, 14:17
FRC #0842
Was there any validity to the following comment that was posted on the YouTube video at
http://www.youtube.com/watch?v=G9y-L...eature=related
dougji I hate to burst your guys bubble, but this is illegal. You're not allowed any "sudden stop" launching mechanisms.
frc1726 (2 days ago) Could you please cite a rule, Q&A response, or team update paragraph that says that? We haven't seen any such thing, and would like to know if you are correct.
What is the definition of a "sudden stop" launching mechanism?
Regards
Frank
  #45   Spotlight this post!
Unread 30-01-2008, 14:34
MrForbes's Avatar
AKA: Jim
I have not found anything that gives it any validity, and I think the person who posted that might not understand how our robot works.
pic: FRC 1726 Steering Prototype MrForbes Extra Discussion 15 12-01-2008 21:21
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: 1726 Demo Bot s_forbes Extra Discussion 6 27-06-2007 12:56
pic: 1726 Ramp Progress s_forbes Extra Discussion 6 19-02-2007 01:14
pic: 1726 2007 OI TheOtherGuy Extra Discussion 2 11-02-2007 23:17
