Re: HELP!!!!! Taigene motor load
Just for the sake of clarity, remember that while using Brake mode will cause your motors to slow down more abruptly, it will not prevent your motor from backdriving. If you want to prevent backdrive, you'll either need to add an encoder and control it in software, add a mechanical brake, or use a motor with a worm gear (such as the Denso).
| Taigene Window Motor Information | CoupeSprinter | Motors | 4 | 29-01-2008 20:27 |
| taigene motor shaft | wildabyss | Technical Discussion | 3 | 24-01-2008 17:11 |
| Taigene Window Motor Specs | master_nickz | General Forum | 0 | 22-01-2008 15:53 |
| Taigene Motor Specs | Guy_E | Motors | 7 | 21-01-2008 03:25 |
| White Paper Discuss: Approx. Motor Spec for Taigene Motor | Joe Johnson | Motors | 2 | 22-01-2005 16:36 |
