Go to Post dont be afraid of new technology. embrace it and experment with it figure out the problems on the way and then tell us about it so it gets easier. - Tytus Gerrish [more]
Unread 30-01-2008, 02:14
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Controlling Two Robots at Once
Since this is our second year, our team now has two driving robots and two operator interfaces, but we cannot control them both at the same time because the team number on the OI is the same. We turned on one OI, and both robots, and it controlled both of them at the same time, which was not very good.
How do other teams work with this? Do you change your team number just to avoid the interference, or is there another way to change the channel?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 30-01-2008, 03:09
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Controlling Two Robots at Once
I would change the team number on the OI, yeah. Our team's never run two robots simultaneously (however this is a very plausible situation, to run as a demonstration for sponsors), so if you would like a more adamant answer I would wait for a team that's done this to respond. Or just put a post-it note on the OI with the changed team number stating this, so that if it DOESN'T work, you can revert it.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 30-01-2008, 04:33
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Change Channels:
Unread 30-01-2008, 08:49
JanTM1191 JanTM1191 is offline
AKA: Jan Mariak
FRC #0369 (Nuts 'n' Volts)
Team Role: Driver
JanTM1191 is an unknown quantity at this point
Send a message via AIM to JanTM1191 Send a message via MSN to JanTM1191
yea, u should change the team number, this happend to us once, our team was showing off two of our robots to the incoming freshmen to our school , one from 2007 and 2006 and we had the same problem, the robots were being controlled from one OI, we tried changing the channel buit that didnt help, but then we changed the team # and it worked
Unread 30-01-2008, 15:24
Dylan Gramlich's Avatar
Dylan Gramlich Dylan Gramlich is offline
Christian group in FIRST? Ideas?
FRC #1126 (SparX)
Team Role: Tactician
Dylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond repute
Send a message via AIM to Dylan Gramlich
You could always just use a tether for one of the bots. But i am not sure of the situation so that may not work.
2005-2008: Student Mechanical and Strategy Lead
2009-2010: Mechanical Mentor
2011-2013: Strategy and Field Team Mentor
Unread 30-01-2008, 15:33
joshyboy9987 joshyboy9987 is offline
FRC #0706
joshyboy9987 is an unknown quantity at this point
I think when we do it, we just use different radios. Use one of the 04 radios or something.. That way they don't even send the same signals.
Unread 30-01-2008, 16:04
The Lucas's Avatar
CaMOElot, it is a silly place
That would work but they are a second year team so I would assume they only have the new version modems. Change both the Channels and Team Number.
Be very careful using any powering any OI that you are not accidentally controlling the other robot. Tether robots when you can. I have seen incidents where one sub-team is trying to test one bot and ends up controlling a different bot another subteam is testing. Very Dangerous!
Robot Inspector
Video of FRC488 lifting two robots Madison Robot Showcase 15 08-01-2008 16:45
Controlling a Mecanum drive with two joysticks? Leav Technical Discussion 9 09-12-2007 19:11
pic: PNW - Semifinal 2.3 - FRC488 lifts two robots. Madison Extra Discussion 0 12-06-2007 22:51
two robots utishpenguin Rumor Mill 26 03-10-2002 02:57
