Go to Post A good driver will always win over a good robot. - Mike Norton [more]
Unread 30-01-2008, 07:46
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: How much air do we need?
The clippard (model AVT-32-16) tanks hold 16 cu in (cubic inches) and each piston you want to use has an extended volume of 75 cu in. The clippards can be pressurized to 120psi (pounds per square inch).
Example: If you took 16 cu in (@1psi) and compressed it to 8 cu in, you would have 2 psi
So working backwards, if you contained 120 psi in (4) 16 cu in volumes, you would have 7680 cu in of air stored in the (4) clippards.
Now if you release that volume of air (7680 cu in) into (2) 24" pistons, and combine the (6) volumes (4 clippards and 2 pistons ) 16*4 + 75*2 = 214 cu in, or 7680/214 = 35psi
So (2) pistons connected to (4) clippards will fully extend with 109lbs of force and balance to 35psi.
That is only on the upstroke.
On the return, your tanks would then be at 35psi, or 2240 cu in
So 2240/214 = 10psi and 32lbs of force.
As far as dropping after the match, you can just let gravity do that and leave the top of your cylinders open.
www.179swampthing.org
How much do you need to raise? efoote868 Fundraising 15 28-11-2006 15:40
How much do you need to raise? roninmedia Fundraising 3 30-03-2003 18:09
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
$$$ How much do your students need to raise? Please respond!!! archiver 1999 7 23-06-2002 23:03
How Much? purplehaze357 Off-Season Events 12 17-05-2002 16:04
