Go to Post I'm going to go out on a limb and say that we have to displace objects and/or robots in order to score points. - pfreivald [more]
Unread 29-01-2008, 19:22
govvijay govvijay is offline
FRC #0540
govvijay is an unknown quantity at this point
MPLAB SIM : Stack Overflow Error
I saw a thread where one person got this error in MPLAB Sim:
CORE-E0001: Stack over flow error occurred from instruction at 0x003d3a
The reply was that you have to use the simulator macro in the build options under the C18. How do you do that? Also, what is the stack over flow error? Why does the "watch" window of the simulator not show the variables used in the program?
Thanks for your help.
Unread 29-01-2008, 20:20
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: MPLAB SIM : Stack Overflow Error
A stack is basically memory where you store data temporarily. When you call a function in C, it pushes the data on the stack, after the function returns, it pops it off. The stack is only a certain size and it is possible to push more data onto it than there is memory. I guess that's when an overflow occurs, I don't know what's making it overflow from what you've posted.
The two actions relate to the stack are push and pop.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 30-01-2008, 08:38
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
The stack is used in C whenever a function is called. The compiler can use it for passing parameters, storing the address at which execution will resume when the function returns, and temporary storage for local variables (those declared within a function). The stack is a limited resource. Stack overflow can occur if your function call depth is too great. Function A calls B, B calls C, C calls ...., you get the idea. At some point you will run out of stack space.
A recursive function (one which calls itself) can generate a stack overflow if it has an error which causes an infinite loop or simply is called recursively so many times that all space is used (as described above).
Post some code if you would like further analysis.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 30-01-2008, 09:46
The 2004 Programming Reference Guide addresses how to get the simulator running. You can download it from this page: http://ifirobotics.com/rc.shtml
I don't know if the simulator works with Kevin's new code, but it does with the IFI code when you follow those instructions.
Unread 30-01-2008, 10:38
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
In my recent experience, MPLAB SIM is not compatible with Kevin's new library. It seems to get hung up waiting for an interrupt during the FRC initialization which never occurs (a timer interrupt, perhaps?). The result is a stack overflow before any of the user code is executed. Stepping over it doesn't seem to have any net-positive effect. At this point, even if it were working it's a bit too late in the game to be useful. We wound up using our 2007 bot as a testbed instead.
Unread 30-01-2008, 16:46
FRC #0540
Could be the new code - we are basing our code off Kevin's gyro code.
Unread 10-02-2008, 16:39
robofan robofan is offline
FRC #0540
robofan is an unknown quantity at this point
I solved stack overflow issue by adding the following code to ifi_frc.h:
#ifdef _SIMULATOR
#define RESET_VECTOR 0x000
#define HIGH_INT_VECTOR 0x008
#define LOW_INT_VECTOR 0x018
#else
#define RESET_VECTOR 0x800
#define HIGH_INT_VECTOR 0x808
#define LOW_INT_VECTOR 0x818
#endif
Also, you need to remove or comment out the following lines in ifi_frc.h:
//#define RESET_VECTOR 0x800
//#define HIGH_INT_VECTOR 0x808
//#define LOW_INT_VECTOR 0x818
Using MPLAB SIM koenig3456 Programming 5 11-02-2008 14:39
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
MPLAB SIM debugger Questions Chris_Elston Programming 2 16-01-2005 11:28
MPlab error ryan_f Programming 9 24-05-2004 07:30
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
