Go to Post My first instinct was inflatable clowns and 5 of them beating on the robots at all times, but then I thought, thats probably not right. - Dan Richardson [more]
Unread 30-01-2008, 09:16
Joining the 900 Meme Team
FRC #0079
Telling alliance in the code
Is it possible to tell which alliance you are on in the code? I recall a few years ago (2005 I think) there was an LED that flashed red or blue depending on your color. If anyone knows if it is still possible to check color of alliance I would like to know how. Thanks.
Unread 30-01-2008, 09:50
Re: Telling alliance in the code
I don't know of any documented way to tell which alliance you're on. I'm not even sure if that information is part of the field communication this year.
Unread 30-01-2008, 09:54
FRC #0079
What about telling what channel you are recieving data on. Since each radio transmits on a different channel could you tell your color from that? If so, how could you read that?
Unread 30-01-2008, 10:22
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
My suggestion would be to add a simple switch connected to a digital IO. Since you will know your alliance before you queue, just have the drivers flip the switch to whatever alliance you are on.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 30-01-2008, 10:30
FRC #0079
That is most likely the simplest solution and what I will end up doing. I just thought that it would be kind of cool to do it in code.
Best Alliance in the Alliance Era of FIRST Corey Balint General Forum 28 05-09-2006 20:14
pic: The winning alliance from the Israel Regional aviv Extra Discussion 2 08-04-2006 18:29
The Winning Alliance From the UTC New England Regional archiver 2001 2 24-06-2002 01:39
Pact of Secrecy (Stop Telling US!) Joe Matt Rules/Strategy 17 30-01-2002 01:02
