Go to Post And the rest of the team helped them, encouraged them, and made a big deal about how awesome it was that we were competing for the Chairman's Award. - Carolyn_Grace [more]
View Poll Results: Did you have this gyro issue?
Yes 5 38.46%
No 8 61.54%
Voters: 13. You may not vote on this poll
Unread 28-01-2008, 22:04
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Gyro Warning
This is just a warning to teams who have experienced the same problems we have been having with this year's gyro:
To start out, we read to manual, ect and wired up the left pins (The side with the white cable connected to the pin labeled "R" where the other were ground or 5 volts) and plugged it into analog port 1 on our RC. We proceeded to code up a simple test and print program using WPILib.
What we got for output was one of two things:
Consistent zeros
OR
A constantly increasing value
These are not the results we expected. All information indicated that the values should increase when the gyro was rotated right, decrease when rotated left, and stay the same when the gyro wasn't being moved.
So I went to the WPILib forums and described the problem. Being new to analog sensors in general and WPILib in specific this year, I firgured I messed up the code somehow. I went back and forth with Brad Miller, who was very helpful and even ran the code I posted for him on a VEX to check it, and everything seemed in order to him, except the fact that it would behave for me.
So I left it for awhile and helped with other stuff on the robot, tinkering once and awhile.
So today, I was working on it, and asked another team member to take another look at the electrical part. i had already checked it with a multimeter, and didn't have much hope for that option. I went and did something he needed me for, and he took a look at it.
I get back and he says "You know, there are more paths to this other set of pins than the one we're hooked up to. I've seen boards mislabeled before."
So, hoping he was right, I plugged a cable into the other set of pins. then I rant he same program I had been running. Low and behold, it worked. It started behaving like it should.
So, basically, what I'm saying is that this year's gyro, which IS a different model than last year's, is either labeled using different conventions (T no longer stands for temp but twist or something) or some of the boards were just plain mislabeled. If you are having the same problems we did, give it a try, the worst you can do is output a weird number to the terminal.
CRUD Name: Windows
Alumni to Team: 350
Unread 28-01-2008, 22:18
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Gyro Warning
Originally Posted by Ryan O View Post
(The side with the white cable connected to the pin labeled "R" where the other were ground or 5 volts) and plugged it into analog port 1 on our RC.....
So, basically, what I'm saying is that this year's gyro, which IS a different model than last year's, is either labeled using different conventions (T no longer stands for temp but twist or something) or some of the boards were just plain mislabeled. .
From the Sensors manual
"The Yaw Rate gyro receives 5V from the RC and connects to two of the robot
controller’s analog inputs. Please note that the output labeled “T” is for “Twist” or
rotational velocity. The output labeled “R” is “Relative Temperature”."
Somewhat confusing, but specifically called out.
Twist is what you are looking for.
Unread 28-01-2008, 22:26
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Gyro Warning
T definitely stood for Twist last year, too. Understandably irritating, but at least consistently so.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 28-01-2008, 22:56
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Gyro Warning
I just went through this today too
You figure "R" would be for rotation and "T" would be for Temp
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 29-01-2008, 00:45
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Gyro Warning
I'll admit I was confused by this too I've been using Analog Devices eval board gyros since before the PCB kit gyros were in existence, so I never wired a kit gyro before this year. Another team asked a question about the kit gyro so we wired it up to test its behavior ourselves. When I looked at the gyro, my first instinct was "R" was for "Rate" (it is a yaw Rate sensor) but I asked someone to check the sensor manual. He said "T" was for "Temperature". It made sense so a student wired the "R". We tested it, it didnt work.
The meeting ended and I couldn't figure out what was wrong. I was thinking "some help I am, I don't know how to wire the kit gyro". By chance, I looked at the WPILab doc that night and noticed the "T" was wired. Of course then I realized what was wrong. The next day, we fixed it and all had a good laugh about "Relative Temperature" and "Twist". We all agreed that the gyro labeling is counter intuitive.
Robot Inspector
Unread 29-01-2008, 14:32
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Re: Gyro Warning
This is the first year that our team is using gyros at all (I just seem to be good at dead reckoning...). So, I thought that T was Temperature and R was Rotation...apparently I was wrong but when I got nothing for an output I just read the sensor manual and was set straight.
Just remember, 'Reading is Fundamental' ^_^
Unread 30-01-2008, 12:23
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Re: Gyro Warning
Dumb question. Kevin Watsons code appears to not require the "R" (Relative Temperature) connection to the RC at all. Am I reading this correctly ?
Unread 30-01-2008, 12:35
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Gyro Warning
Correct, you don't need it.
-Kevin
Kevin Watson
http://kevin.org
Unread 30-01-2008, 12:43
The Lucas's Avatar
Re: Gyro Warning
Correct. The "R" Relative Temperature is most often not used (do any teams actually use it?). Temperature does affect the rate output on the gyro but not significantly in the context of a FIRST match (IMHO). You could write code to correct for temperature effects (has anyone?), but I dont think it is worth the time during build season.
Robot Inspector
Unread 30-01-2008, 12:47
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Gyro Warning
-Kevin
Kevin, call me curious george here, but is the reason you don't need it because you find the mean value before starting to use the gyro? Is this what changes with temperature?
Thanks,
q
p.s. Unfortunately no camera this year, so for the first time in two years the code doesn't compile as camera.hex. Thanks for sorting through the camera specs and writing a driver those couple years ago, it was a beast!
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Autonomous Warning petek Chit-Chat 3 15-01-2007 18:58
Misinformation warning Lil' Lavery Rumor Mill 96 03-12-2004 19:28
warning about taxes robot180 Chit-Chat 3 16-10-2003 17:36
Warning Label!!! Mark Garver General Forum 15 05-01-2003 23:55
RSAD Warning archiver 2000 4 23-06-2002 21:59
