Go to Post Will we finally get to play music on our robots for once!? - Hitchhiker 42 [more]
Unread 30-01-2008, 12:33
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Pinning a Mechanism
How much power will it take to remove a pin, if 200 pounds of force acts in the perpendicular direction? Would a pneumatic piston work?
2007 - NASA/VCU Regional Winners (Thanks 2108 & 843!)
2006 - Championship Curie division
2006 - NASA/VCU Semi-Finalists (Thanks 510 & 587!)
2005 - NASA/VCU Quarter-Finalists (Thanks 388 & 619!)
Unread 30-01-2008, 12:41
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Pinning a Mechanism
Depends on the pin. You'd have to overcome the force of friction, which is the perpendicular force (200lbs in this case) times the coefficient of friction. If you can make the coefficient of friction small (by using slippery materials) then it should not take too much force to pull the pin.
Unread 30-01-2008, 12:42
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Depends on the size of the pin, the material of the pin, the material that the pin is going into, and the shape of the pin.
Unread 30-01-2008, 12:49
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Is this holding back a spring?!
Wow remind me to borrow some hockey gear before i stand by the field this year...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 30-01-2008, 12:51
Rob2713g's Avatar
Yes, we have a spring like force on the other side. I uploaded a pic to CD-media.
Unread 30-01-2008, 13:11
Rob2713g's Avatar
The force pulls to the right along the orange rod/string.
http://www.chiefdelphi.com/media/photos/29966?
Pinning opponents TRACKBALL popo308 Rules/Strategy 3 14-01-2008 22:07
Clarification on Pinning Stu Bloom Rules/Strategy 2 15-03-2006 05:07
Ramming/ Pinning f22flyboy General Forum 21 07-03-2003 20:39
Pinning the Goal DaringCommander Rules/Strategy 8 27-01-2002 11:57
