Go to Post There's more than one way to skin a cat. - Al Skierkiewicz [more]
Unread 30-01-2008, 13:03
Southgate Servo Southgate Servo is offline
FRC #2620
Southgate Servo is an unknown quantity at this point
Rookie team in need of help
Is there a specific way you connect the rockwell terminals to eachother and with the end barriers and end anchors?
Unread 30-01-2008, 13:09
WaterFreak WaterFreak is offline
FRC #0708 (Hardwired Fusion)
WaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to beholdWaterFreak is a splendid one to behold
Re: Rookie team in need of help
Yes.
Included in the KOP was a YELLOW jumper bar (PN: 1492-CJJ12-4) [in the BLACK tote] that you can use to connect multiple Rockwell terminal blocks together.
You can customize the jumper by just cutting it to the size you need.
BE CAREFUL, you will only get one chance to cut is, so be certain of what you need.
Thanks, Jim Orr
Senior Software Engineer - Motorola, Connected Home
Supporting Team 708 - Hardwired Fusion
Unread 30-01-2008, 13:22
FRC #2620
ok thanks for all the help
Unread 30-01-2008, 13:25
FRC #2620
is there a way to attach the end anchors to the dim rail?
Unread 30-01-2008, 13:46
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Section 10.2.5.4 of the manual has detailed instructions and a diagram to aid in assembling the Rockwell blocks. http://www.usfirst.org/uploadedFiles...Parts-RevB.pdf
Make sure all wires being inserted into the block are stripped to 5/8" to ensure you are getting only copper and not insulation in the screw terminals. If you clamp down on the insulation it's going to wiggle loose, probably at the worst possible time.
Maximum Wire Size and Max Quantity Allowed per 1492-J16xx Terminal
1 - #6 or
1 - #8 or
2 - #10 or
3 - #12 or
4 - #14 or
4 - #16
Another thread that has discussed this topic recently is:
http://www.chiefdelphi.com/forums/sh...ad.php?t=61981
There are pictures of a correctly assembled PDB included.
Unread 30-01-2008, 16:10
Section 10 TheKitofParts RevA, has a procedure and drawing of the correct way to assemble the Rockwell Block. You do not need all the blocks if your design does not require them. You may cut the yellow jumper to size for your design.
Rookie team in need of help???? RRA4LIFE2 Programming 2 23-01-2008 21:49
Rookie team in need of a lot of help OregonRoboHawks General Forum 25 22-01-2008 10:31
Rookie programmer in need of help. kshot Programming 7 20-01-2005 15:05
Rookie Competitions - we need help Bob Steele Regional Competitions 6 24-01-2003 23:29
HELP! Rookie team up the creek w/o a paddle andy General Forum 17 07-01-2003 19:48
