Go to Post Ah, to be a teenager and know everything again. - Alan Anderson [more]
Unread 30-01-2008, 14:01
Kinghound Kinghound is offline
FRC #2074
Kinghound is an unknown quantity at this point
IR board help
Could someone tell me what kind of connectors you used to hook up the IR Board, and how you did it. Or could you send me a picture or the link to a picture.
Unread 30-01-2008, 18:05
SuspectZero's Avatar
SuspectZero SuspectZero is offline
2254 Team President
FRC #2254 (Twisted Transistors)
SuspectZero is an unknown quantity at this point
Re: IR board help
i dont want to open a completley new thread for this question, so i hope you don't mind me throwing my question in here too. my question is how do we hook up the IR Board to the digital inputs. like we have our 4 wires that are outputs from the board, do those go directly to the signal on the digital input and thats it? or do we have to hook up ground to something as well. also where can the power cables go from the ir board? currently we just have them hooked up to a 9v battery.
Team 2254: Twisted Transistors
2007 FRC: Placed 18th in Regionals
2008 FRC: TBD
Unread 04-02-2008, 13:12
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: IR board help
we cut up some PWM cables, for the 3-wire male and female ends. The IR's command outputs from the ribbon cable need to get spliced into 4 separate PWM cables ... but only the signal pin ... you can leave the + and - wires unconnected.
on the provided ribbon cable, pins 1 & 2 are (+) and pins 3 & 4 are (-). the next 4 wires are the outputs for CMD 0/1/2/3.
we just wired up those 4 single signal wire, to the 4 inputs on the Dig I/O on the RC. As long as the IR sensor board is getting the same power source as the RC, you are good-to-go, as they have a common return.
Your standalone 9v battery solution won't work reliably unless you tie the (-) side of the 9v battery to the (-) side of your bot-power. Without a common return, you risk zapping either the IR board or the Digital inputs of the RC.
For the connections, during our testing we simply used M and F spade lugs, crimped onto the ribbon cable ... not sure if we'll keep it for the final build.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
Emergency Help Needed on Main Board and Camera amateurrobotguy General Forum 9 09-02-2006 21:22
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
