Go to Post However, as a philosopher, while you need math, you can probably talk your way out of it. - sciguy125 [more]
Unread 30-01-2008, 14:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Stroke Length and Bore Size Limitations
Yes, there are limitations, please see the Pneumatics Manual, and refer to these Robot Rules as well
<R89> In addition to the pneumatic cylinders provided in the Kit Of Parts and the “free” pneumatic cylinders available for order through the Free Pneumatic Components Order Form, additional air cylinders or rotary actuators may be used. All cylinders, regardless of source, must be identical to those listed on the Free Pneumatic Components Order Form (e.g. same part numbers). Any additional air cylinders must source from Bimba or Parker Hannifin, or be recovered from prior year FIRST Kit Of Parts.
<R90> Items specifically PROHIBITED from use on the ROBOT include: Any air compressor other than, or in addition to, the one provided in the Kit Of Parts. Pneumatic cylinders and actuators different from those in the Kit or found on the Free Pneumatic Components Order form, with the exception of those specifically permitted by Rule <R89>.
the free cylinder sizes are listed here
http://www.bimba.com/FirstFree.aspx
calculating cylinder length from stroke nighthawk0501 Pneumatics 13 14-01-2008 15:33
3/4" bore x 1/2" stroke Bimba Cylinder model sanddrag Inventor 5 16-01-2006 22:14
24" Stroke 1.0625" Bore Piston Legality Yan Wang Pneumatics 4 05-02-2005 09:32
size limitations D: Kevin Karan Programming 6 20-03-2004 21:20
Operator Board Size Limitations?? archiver 2001 6 24-06-2002 00:37
