Go to Post Sometimes the complex can be done very simply. - Cory [more]
Unread 30-01-2008, 16:19
Mrtrom Mrtrom is offline
AKA: Aaron Baker
FRC #0085 (BOB)
Team Role: Animator
Mrtrom is an unknown quantity at this point
Ball Bearings
I am new this year on FIRST, and i was wondering if ball bearings will begin to "lock up" after long periods of use
Unread 30-01-2008, 16:39
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: Ball Bearings
That is one of the nice things about FIRST. Unless you are able to get considerable drive time before the ship date, you do not usually have to worry about Ball Bearings. Think of it this way, 24 hours of running your robot equals about 640 matches, with very little continuous use. We have never had problems with ball bearings on our robot. I guess it depends on what you consider long periods of use.
EDIT: Making certain that they are lined up to begin with also helps.
Unread 30-01-2008, 16:56
Happy Birthday! EricH EricH is offline
Re: Ball Bearings
I've never ever seen a ball bearing lock up in FIRST. 330's practice robot last year went through the mill--the drivers barely waited for the batteries to charge before driving again; it won a preseason, and is still running today. No bearing failure.
Unread 30-01-2008, 18:26
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Ball Bearings
Ball bearings usually are overkill for a FIRST application and should last far beyond the life expectancy of your robot.
A couple of things to note: Ball bearings like even loads meaning that the shaft that goes through the bearing pack (I'm assuming you are using a bearing pack and not just ball bearings in a channel) is in line with the hole and not canted. The other thing is that ball bearing packs tend to not like side loads.
___________________
- Tennyson, Ulysses
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 15-01-2008 23:27
Purchasing Ball Bearings FIRST JerseyKid Kit & Additional Hardware 7 30-04-2007 09:11
Where to buy Ball Bearings? ThatIndianKid89 Kit & Additional Hardware 3 20-01-2007 15:59
Threaded rod through ball bearings Madison Technical Discussion 38 03-01-2007 01:23
Drills: The ball bearings are gone? BobbyG Motors 0 21-01-2003 23:57
