Go to Post If winning that individual match is more important to you than being there in the first place, then I believe you've got your priorities in the wrong spot. - Tom Bottiglieri [more]
Unread 30-01-2008, 16:24
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Chassis
Our team has a question for yall. How low can the bottom of the chassis be, and does the bumper have to cover the entire chassis. (eg. the bottom of the chassis sticking out of the bumper.)
Unread 30-01-2008, 16:30
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
Re: Chassis
As low as you want. Just remember that there are bumps for the lane divider supports that are about 1/2" tall.
Bumpers must be within a 6" zone, between 2.5 to 8.5 inches from the floor. Since a bumper is 5" wide, you have the option of where that extra inch goes. In other words, the bottom of the bumper could be from 2.5 to 3.5 inches from the floor.
You can have parts of your robot that are lower than the bumper, but they cannot be sticking out underneath the bumper. The bumper forms the outer surface. Obviously a manipulator of some sort is exempt from staying within the bumper area. You must take care that you do not damage or wedge another robot with your extension.
(since 2004)
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Chassis
The bottom of the chassis can be as low as you want but I would caution you against being ridiculously low since there is a 1/2" bump in the field. Also bumpers only have to cover 2/3 of the chassis.
Mentor 2415
Chassis Materials neoshaakti Technical Discussion 30 12-11-2007 21:08
Chassis Clearance T3_1565 Technical Discussion 7 08-01-2007 18:02
Chassis? jakey Kit & Additional Hardware 1 09-01-2006 15:10
chassis weight ?! groves General Forum 49 27-01-2003 17:36
Chassis ark_1230 Technical Discussion 2 04-09-2002 22:51
