Go to Post (middle school age) One time I had a truly awful day at school and came home crying. My mother's response? "Do you want to go to the build session tonight? It will make you feel better.." And it did. It always does. - rachelholladay [more]
Unread 30-01-2008, 16:43
Omni Omni is offline
FRC #0121
Omni is an unknown quantity at this point
Trouble building code
ADC_CH0 not defined (error msg on build)
in ifi_frc.h add the line #include <adc.h> after #include <p18cxxx.h>
Has anyone else had this problem with missing code?
Unread 30-01-2008, 17:47
fallen751 fallen751 is offline
FRC #2052
fallen751 is an unknown quantity at this point
Re: Trouble building code
well it seems that in either the ADC.h header file ADC_CH0 (which I believe is analog to digital convertor channel 1) isn't defined...which is strange. if you comment out the offending refrences to ADC_CH0 do you recieve a second error about ADC_CH1? can you post your direct error message up here?
Unread 30-01-2008, 18:33
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
Do you happen to be using rc_ana_in01 some where in the code you wrote? We got a very similar problem when one of our programers wrote
Get_ADC_Result(rc_ana_in01);
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
Trouble using Kevin Watson's Serial Code with Vex user API StargateFan Programming 3 13-01-2007 15:42
Autonomous Code trouble The yellowdart Programming 16 21-01-2006 10:36
trouble with beacon tracking code [53] opticruzer Programming 9 27-01-2004 12:19
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
Some code in C that we may need if we are in trouble Andrew Rudolph Programming 0 04-10-2003 10:44
