Go to Post As a Mississippi boy, I'm especially proud that I could read - Natchez [more]
Unread 30-01-2008, 17:27
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
Can we use last years code?
I see Kevin Watson has new code for 2008. But can we still start from last years code? If we build on what we wrote the last few years, will the autonomous code still get called in tele-operated mode, and the robot still operate at the match?
Unread 30-01-2008, 17:34
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Can we use last years code?
yes....i think....you can use the old code....it works the same.
Unread 30-01-2008, 21:59
Originally Posted by steve d View Post
...can we still start from last years code?
You can start with it, but you need to be very careful not to leave any of the code you wrote last year unchanged.
Originally Posted by <R78>
Unaltered software modules developed by the team during prior competitions shall not be directly re-used. Just as designs for hardware COMPONENTS may be reused from one year to the next, software algorithms and designs may be reused. However, the specific lines of code must be customized for each ROBOT each year.
It would probably be better to start with the unaltered 2007 default code, then add new functionality based on what you did last year.
Are we allowed to use last year's pneumatics on this years robot? Tri_Lam Pneumatics 2 13-02-2007 23:50
Can we use last years CIM's? Arkorobotics Motors 8 05-02-2006 01:59
can we use motors from last year's kit? Amittt Motors 5 22-01-2006 22:27
Can you spare last year's code? dark.shadow15 Programming 3 28-10-2004 16:21
Last minute 'can we use'? Radiant Phoenix Kit & Additional Hardware 3 20-02-2002 19:02
