Go to Post I would rather KEEP the structural integrity of my skull, thank you. - carpedav000 [more]
Unread 30-01-2008, 17:44
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
PID for velocity control
We want to implement a PID for velocity control of the left and right motors. We understand how a position PID works, but for a velocity control, when the motor reaches the desired velociy, the error will be zero, therefore, it will only have the I and D terms to keep it driving. Is that enough? In this case would the integral sum never be cleared?
About resolution: Right now we get around 1200 counts per second at full speed from the gear tooth sensors. If we wait for 100ms that will give us a speed range of 0-120. Should the PID calculation only run at the same rate? If the PID loop runs ever 26 ms, it will aleady have run three times before we have a speed update. Whats a good balance of PID loop time to data update time?
Is the 26.2ms main loop stable enough to run the PID in or should it have its own timer?
Thanks,
Brian
Brian K
Team 1225 Robotics Mentor
Integral Window for PID Control phrontist Programming 2 16-02-2008 17:32
paper: PID Control Theory for FRC Programming Matt Krass Programming 17 24-05-2007 03:28
What constants are u using for high velocity PID Salik Syed Programming 3 18-02-2006 23:22
Problems Using PID for Velocity Astronouth7303 Programming 6 10-02-2006 09:00
Manual Velocity PID, anyone successful? Chris_Elston Programming 20 31-01-2006 20:51
