Go to Post Looks to me like they have a tasty robot. - Andy Baker [more]
  #316   Spotlight this post!
Unread 28-01-2008, 23:22
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by wcarr View Post
I was wondering if the message you have in adc.c:
* This version will only work with PIC18F8722 based robot
* controllers. You should use version 0.3 of this software
* with a PIC18F8520 based robot controller.
is still valid. And if so, how would I go about getting version 0.3 of the adc!
Yes, that version will only work properly with the '8722. I'll be releasing a unified version soon that will work with both robot controllers and C18 2.4 & 3.0+. I'll release it when I'm finished with a major revision of the gyro code.
-Kevin
(If you can't wait and promise to report any bugs you find, here's a snapshot of the latest build without the gyro mods)
Kevin Watson
http://kevin.org
  #317   Spotlight this post!
Unread 29-01-2008, 14:10
FRC #2429
I've posted a snapshot of what I hope is the last build for a while. The changes are numerous and include improved gyro code. The documentation still needs some work, but the code should be complete. If you're willing to test it and provide feedback and/or bug report(s), you'll find it here: http://kevin.org/frc/ifi_frc_sensor.zip.
-Kevin
Kevin Watson
http://kevin.org
  #318   Spotlight this post!
Unread 29-01-2008, 16:20
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Get_Gyro_Rate() returns jumpy values
when I call Get_Gyro_Rate() it tends to give occasional outliers and data that doesn't make sense. When I turn the gyro constantly one direction, jumps back and forth between positive numbers. Get_Gyro_Angle() works fine and is accurate. I am testing with last year's kit gyro.
  #319   Spotlight this post!
Unread 29-01-2008, 16:29
Re: Get_Gyro_Rate() returns jumpy values
Originally Posted by sparrowkc View Post
when I call Get_Gyro_Rate() it tends to give occasional outliers and data that doesn't make. When I turn the gyro constantly one direction, jumps back and forth between positive numbers. Get_Gyro_Angle() works fine and is accurate. I am testing with last year's kit gyro.
You might be seeing the issue resolved here.
  #320   Spotlight this post!
Unread 29-01-2008, 16:31
AKA: Mark
I downloaded the Sensors code from Kevin's site just yesterday, was it not fixed then?
  #321   Spotlight this post!
Unread 29-01-2008, 16:42
FRC #2429
The public version on the website still has the bug. I hope to replace that version with the new version (link a few messages back) tonight after you guys (hopefully) try it out and report any issues.
-Kevin
Kevin Watson
http://kevin.org
  #322   Spotlight this post!
Unread 29-01-2008, 22:58
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Just transferring the new code over to my dev. code.
Noticed that the Get_Gyro_Bias_Status() function looks like a bad cut/paste from another function. No return value.
unsigned char Get_Gyro_Bias_Status(void)
// zero out gyro_angle
gyro_angle = 0L;
Phil Malone
http://www.GEARSinc.org
  #323   Spotlight this post!
Unread 29-01-2008, 23:00
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Other than the Get_Gyro_Bias_Status Phil noted above, I haven't found any problems with the latest code. I only messed around with the relativly simple stuff today - I'll be doing some more intensive encoder and gyro (maybe) based testing tomorrow, so I'll let you know about those after I do that.
  #324   Spotlight this post!
Unread 29-01-2008, 23:02
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: New C18 3.0+ Compatible FRC Code - New Build
Great work Kevin
had running a gyro, a MatBotrix Ultrasonic ranger and an encoder!!!!
To get values from the MatBotrix, I needed to use Get_ADC_Result and then Convert_ADC_to_mV....the Get_Analog_Value didn't work.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #325   Spotlight this post!
Unread 29-01-2008, 23:31
FRC #2429
Ouch. Let me see what happened...
-Kevin
Kevin Watson
http://kevin.org
  #326   Spotlight this post!
Unread 30-01-2008, 00:13
FRC #2429
Thanks!
-Kevin
Kevin Watson
http://kevin.org
  #327   Spotlight this post!
Unread 30-01-2008, 00:16
FRC #2429
I don't know what I did, but the correct version should be on the server. Thanks again for your help.
-Kevin
Kevin Watson
http://kevin.org
  #328   Spotlight this post!
Unread 30-01-2008, 00:29
FRC #2429
I'm pretty sure you'll get corrupted data if you try to use Get_Analog_Value() while the ADC code is running in the background.
-Kevin
Kevin Watson
http://kevin.org
  #329   Spotlight this post!
Unread 30-01-2008, 18:38
Lummis1647's Avatar
Lummis1647 Lummis1647 is offline
FRC #1647 (Iron Devils)
Team Role: Scout
Lummis1647 is an unknown quantity at this point
I'm having a huge problem with the lastest code I just downloaded 2 hours ago. I'm using version 2.4 of the compiler. I followed all of the instructions in the readmes, but if I call Initialize_ADC(); and Initialize_Gyro(); in teleop/Initialization(), I'll get a blinking red and green light next to program state on the rc. On the output window, "IFI User Pr" shows up, making me think that it runs into an error in the middle of trying to print the printf:IFI User Processor Initialized ...\r\n. There are no problems when those 2 function calls are commented out(initialize gyro and adc). I've tried a combination of commenting and uncommenting the gyro code in teleop and the process_gyro_data function in teleop_spin. I don't get this problem with an earlier version of the 2.4 gyro beta code. I'm really not sure what to do. Any one else have this problem? Does this work for anyone using 2.4- the hex file builds and in ifi_frc.h I have USE_C18_24 #defined only. I'd really appreciate any suggestions. Thanks.
  #330   Spotlight this post!
Unread 30-01-2008, 19:37
FRC #2429
My guess is that you didn't enable the timer 4 ISR in ifi_frc.h.
-Kevin
Kevin Watson
http://kevin.org
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
