Go to Post Admiring the new chassis: "Oooo, nerd bling!" - Rick TYler [more]
Unread 30-01-2008, 20:58
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
toughbox gear/shaft slippage
Has anyone noticed that the drive shaft gear is a loose fit on the drive shaft? That is a bad thing, correct? I guess it will wear over time but it should be a pretty tight fit to begin with, right?. We took a toughbox apart (we have been abusing for a few days testing software) and it was a noticeably loose. But when we went to replace it with a new piece, they are loose also (tried 3 separate gears and shafts). It seems to be designed that way!
Please help a poor EE trying to diagnose a mechanical problem.
TIA
Banebots 1/2" shaft encoder for Toughbox? MrForbes Electrical 11 24-01-2008 21:40
Matching a Gear to Keyed Shaft of DC Motor Spindle Motors 9 22-05-2005 20:23
Window Motor Output Shaft Spur Gear Specs archiver 2000 1 23-06-2002 22:56
Connecting new gear to shaft? mnkysp6353 Technical Discussion 10 29-01-2002 05:12
