Go to Post Remember the volunteering is not mandatory for the people to do it. It IS mandatory if FIRST is to survive and the regionals to leave a positive impact on everybody. - Alavinus [more]
Unread 30-01-2008, 21:01
bizarospooky bizarospooky is offline
FRC #2642 (Falconaters)
bizarospooky is an unknown quantity at this point
Freaky Error
Not sure why our robot is doing this, but we push the joystick full forward and then full back it gives us a programming error and at one point read 8.3 something volts on the OI. We have tried changing the joysticks, reversing the motor polarities, and then we went down to the most baisic code in EasyC (the compiler were using since I'm lazy and I'm the only programmer) for driving in arcade style of Arcade 2 Motor style. We are still getting the error, so we tried calibrating the victors, that didn't work. We tried change the jumper from coast to brake, and in brake it well breaks faster. One thing we were talking about is whether or not the arcade drive function ramps up the speed depending on where the joystick is and if not how to implement it.
I am of course using EasyC, though I could go to the Microlab compiler I just don't want since again I'm kind of lazy and have to train someone who has no real C experience since I am a senior this year and will not be here next year.
Unread 30-01-2008, 21:03
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Freaky Error
Did you try a fresh battery?
Unread 30-01-2008, 21:08
Re: Freaky Error
There was a problem with the IFI code 2 years ago which caused the battery voltage to show 8.2 or 8.3 volts. It required new libraries and a new linker file. You can read about it here: http://ifirobotics.com/docs/memory_problem_8722.pdf
I have no idea if easyC implemented those changes or not.
You will also see wierd things if the battery is low and the backup battery is not attached.
Unread 31-01-2008, 18:38
Re: Freaky Error
I think the battery was the problem, we put the battery on medium charge speed and it said it was fully charged so we assumed. We put it on the charger after trying the second battery and the charger said it was empty. So batteries are charging and we will test tomorrow.
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
pic: Me with 364's freaky totem Kris Verdeyen Extra Discussion 2 24-03-2007 15:51
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
Freaky Eon8 Cuog Chit-Chat 12 01-07-2006 01:06
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
