Go to Post but eventually it seems that we realize that there's an I in FIRST, and the I stands for Inspiration, not for "me" - MrForbes [more]
Unread 29-01-2008, 16:22
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
Relay program?
I need help trying to figure out a program. I want to engage a relay when my right and left drive motors are between 125 and 129. I thought it would be something along the lines of 125 < x < 129 but i cant seem to get this to function can anyone help me out?
Unread 29-01-2008, 16:31
Re: Relay program?
Comparisons don't "chain" like that in C. Do it this way:
if ( (125 < x) && (x < 129) )
The inner parentheses aren't strictly necessary, but I think they make it much more readable.
Unread 29-01-2008, 16:40
Code Monkey Code Monkey is offline
FRC #1622
Code Monkey is an unknown quantity at this point
Re: Relay program?
do a printf of x. You may not be getting the PWM value you think you are.
We have had problems with pwmXX values not being available in all of our subroutines. If that is working, try a nested if-not as elegant, but it works.
Lastly try increasing the band you are allowing on 127-your offset may be off or you go through it too fast.
Check that your value to the relay routine call is a logical 0 or 1 (try forcing it)
Unread 30-01-2008, 19:40
team877's Avatar
Re: Relay program?
i was thinking i needed to set my x value to say (pwm 1) if i wanted it to work with my pwm. But i tried using pwm control with the x variable inside it and it just makes my pwm continually run is there something i'm missing
Unread 30-01-2008, 22:40
Re: Relay program?
Show us the code you're trying to make work. Tell us exactly what you want it to do, and we can tell you what to change to make it do that.
Unread 02-02-2008, 12:03
team877's Avatar
Smile Re: Relay program?
here is our code you asked for....
Unread 02-02-2008, 12:39
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Relay program?
where are you setting the value of x?
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 02-02-2008, 13:26
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
Re: Relay program?
Where is this file in the overall scheme of the robot? I don't know how to look at easy C to intuitively know what is going on, but it could be you are calling the function in the wrong place. Is the function called in user_routines.c? It should probably called somewhere from within Default_Routines(). I am assuming the easy C version of the code is organized the same way as just regular code.
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 02-02-2008, 20:13
Re: Relay program?
void operatorControl ( void )
	unsigned char x;
	while ( 1 )
		SetPwm ( 2 , x ) ; //  We’re setting are variable to the motor we want it to measure
		if ( 125 < x && x < 129 )
		{ // We want this relay to engage between these speeds
			SetRelay ( 1 , 1 , 0 ) ;
		else
		{ // And if not turn the relay off
			SetRelay ( 1 , 0 , 0 ) ;
I don't see anything that sets the value of x. Did you forget the line that reads the joystick value?
(Is there a reason you posted it as a Word document containing a picture, instead of just copying the text? I don't use Word, and it was inconvenient to convert your file to a readable form.)
Unread 04-02-2008, 00:53
team877's Avatar
Re: Relay program?
the Setpwm (1, x) is a window that you put your variable in so "x" is set to the value of pwm 1
Unread 04-02-2008, 07:10
Re: Relay program?
Isn't it the other way around? As an output function, SetPwm( 1, x ) sets pwm 1 to the value of x. I'm not aware of a built-in way to read the present value of a pwm output using easyC.
So where in your program do you actually control the pwm output that you want to use as the trigger for your relay?
Unread 04-02-2008, 11:11
Re: Relay program?
Normal operation would be to:
1) Get the desired drive value from the driver--GetOIAInput()
2) Do your tests on when you want your relay to be active--if () else
3) Output your relay command--SetRelay()
4) Set your PWM Output--SetPWM()
Instance relay Team_486 Programming 0 28-03-2007 09:56
Relay Commands Matt Krass Programming 6 18-02-2006 23:03
Relay Assignments MulletFish Programming 9 27-01-2005 14:15
Relay fault archiver 2000 2 23-06-2002 23:36
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
