Go to Post It's 9:00 Do you know where your bott is? - Michelle Celio [more]
Unread 30-01-2008, 22:51
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
keeping orientation with gyro
I am using Kevin Watson's sensor code, And I want to keep the robot in a constant orientation (We have mecannums).
My current method tends to over correct while strafing, and starts to oscilate. Has anybody done this in the past? Tomorrow I am going to do some testing to get some values for an equation that will take into account rotational velocity and determine a coast down time so that the robot doesn't overshoot so much.
Currently I find a turn value with
turn = .14111*tempgyro+127;
and then put turn through my limit function.
Unread 31-01-2008, 01:41
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: keeping orientation with gyro
The limit function should be a closed-loop feedback function, it sounds like. And if it's oscillating, it sounds like you're using just Integrated control (from the PID term you keep hearing). Try a good whitepaper on that subject...
What place are we at? ... TODAI!
Unread 31-01-2008, 23:49
AKA: Mark
I got it, and it is beautiful. This was a good day.
Help With Gyro Bronson Electrical 3 10-01-2008 21:09
Keeping a certain heading using a gyro DanDon Programming 12 08-03-2006 14:27
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Anyone else having trouble keeping up with work? D. Gregory General Forum 36 28-03-2004 16:55
