Go to Post Robot gets bored during practice, wanted to listen to some podcasts. - Tom Bottiglieri [more]
Unread 31-01-2008, 00:12
jasonpeinko jasonpeinko is offline
FRC #1087
jasonpeinko is an unknown quantity at this point
Limiting Motors
We have several things that can only move a certain amount in one direction. One that moves based off user input, and other that when the user presses a button will move to a position and move back when the button is released.
I need some help on limiting the movements, on the one with the button press i dont see an easy spot to place a gear tooth sensor (which we only have 2 of). My question is just using the pwms with the same values to move back and forth accurate enough or not. I dont want to break anything on the robot with it being inaccurate.
The others i think a gear tooth sensor would work but i more sure how accurate they are
Unread 31-01-2008, 00:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Limiting Motors
There are two types of limit switches in the Kit of Parts (two microswitches and a rotary limit switch), try to figure out how to mount one of them so the switch is activated near the end of the desired travel.
Unread 31-01-2008, 01:25
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: Limiting Motors
Also if you have an arm, put it as close towards the center of rotation (but at the end of rotation) as you can, because if it's all the way out on the radius it'll take longer to activate the switch. We fatally bent an arm on accident that way! Had about 2 minutes between semifinal games to replace it. Bad news.
What place are we at? ... TODAI!
Limiting acceleration in easyC Neurovirus Programming 13 02-02-2008 12:50
limiting team membership lallamavolador General Forum 29 15-10-2006 22:47
spike limiting Anton Programming 5 14-02-2005 22:05
pwm ouput limiting stephenthe1 Programming 10 05-12-2004 16:57
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
