Go to Post I think this thread just won "ChiefDelphi is terrible Bingo". - Karthik [more]
Unread 30-01-2008, 14:27
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Rules question about end of match reconfig
At the end of a match is there a rule that says we have to have some way to reconfig the robot to starting config without power? Some have been telling me that we have to be able to move the parts back to starting config after the robot controller is disabled at the end of the match before you move it back to the pits?
True?
Bruce
Unread 30-01-2008, 14:30
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Rules question about end of match reconfig
Not exactly. You need to be able to release game pieces and get the robot into a configuration you're able to transport safely without powering up. You only have to get it all the way into starting configuration for inspection and match starts.
Unread 30-01-2008, 16:26
GaryVoshol's Avatar
Cogito ergo arbitro
Generally, you need to get the robot off the field and to your cart. Then you will probably be able to power up to collapse the arm/tower/lift/whatever so you can safely go back to your pit area. Making sure there is no one in the way who will get knocked about by your appendage.
I'm sure robots will exit the field much faster this year than last, when those ramps had to be folded back up to make the robot of managable size to move.
(since 2004)
Unread 30-01-2008, 16:32
Rule <G45> is probably what your friends have been misquoting.
<G45> Arena Reset - ROBOTS must be designed to permit the release and removal of any TRACKBALLS from the ROBOT without being powered up after a MATCH. If a ROBOT violates this rule, the offending TEAM will be warned and requested to modify the ROBOT. If the modification is not made, the ROBOT may not be permitted to compete in future MATCHES.
Unread 30-01-2008, 16:57
Bruceb's Avatar
What I am thinking about doing is adding a circuit to bypass the spike(driving a window motor) with a switch on the chassis to power the motor in either direction manually to change the configuration at match end. Is there anything wrong with this thought?
Bruce
Unread 30-01-2008, 17:04
Bruce
I can't find anything against it specifically in the manual, save maybe <R62>. I'm thinking it probably won't pass inspection, due to motors having to be wired to a Spike or Victor. However, this should probably be asked in Q&A.
Is the part that you are powering with the window motor going to affect your ability to remove the robot safely? If not, I wouldn't bother. I know of at least one case where a robot had to be returned to the pits in an extra-wide configuration due to design (and window motors), but it wasn't wide enough to cause an issue.
Edit: I found something against it while I was looking for something else:
<R53> Custom circuits shall NOT directly alter the power pathways between the battery, fuse blocks, speed controllers, relays, motors, or other elements of the robot control system (including the power pathways to other sensors or circuits). Custom high impedance voltage
monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, because the effect on the ROBOT outputs should be inconsequential.
As I read it, you are putting a custom circuit onboard that goes around a speed controller. Not legal.
Unread 31-01-2008, 10:11
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Bruce
While i don't know the exact rules that would apply, i'm fairly certain that wouldn't be allowed. I do know several rules require:
- all motors to be powered by spikes or victors
- everything to be powered through one of the circuit breaker panels (either the 40A ones or the 20A)
- All electrical pathways pass through the master breaker (on/off switch)
It's very probable that you'd violate a rule in trying to get fancy to power something after the match. It'd be much better to design in some sort of mechanical release that would allow you to freely move/position your manipulator after the match is over.
End of the Match Zultraranger Pneumatics 10 28-01-2008 15:36
End of match ramp-bot question... AHS1599 Rules/Strategy 1 18-02-2007 12:34
question about rules (size/orientation) Bochek Rules/Strategy 15 19-01-2007 18:23
End of match tethering DirtyBird213 Rules/Strategy 2 15-01-2004 20:29
End of Match Score SkitzoSmurf Rules/Strategy 1 10-01-2004 14:02
