Go to Post "Ugly can win" - Mr. Lim [more]
Unread 31-01-2008, 10:32
MNov's Avatar
MNov MNov is offline
Giant deceptive face
AKA: Matan Nov
FRC #2230 (Zacharia's Angels)
MNov is an unknown quantity at this point
Fuses
Is it legal to connect the air compressor to a 30 amp fuse, or can we only use semi automatic fuses?
Unread 31-01-2008, 10:37
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Fuses
Per R55, your choices are 20 Amp fuse or 20 Amp snap-action circuit breaker.
If the compressor is used, the air compressor Spike relay power feed must be protected with a 20A fuse or 20A circuit breaker. No other electrical load can be connected to this breaker.
I recommend the circuit breaker, which won't usually trip from the current spike during compressor startup. The fuse can really ruin your match if it burns out.
Unread 31-01-2008, 11:16
Re: Fuses
To be more accurate...
<R55> ...
 If the compressor is used, the air compressor Spike
connected to this breaker...
 Relay modules must be protected with a 20A circuit breaker.
The first section allows you to replace the Spike 20 amp fuse with a circuit breaker. If you don't do this now you will later after you have gone through a box of 20 amp fuses. The second section stipulates only 20 amp circuit breakers must protect a relay module.
Start current on the compressor can be 25 amps while run current is 10-12 amps.
fuses Stephen Kowski Electrical 4 08-03-2005 12:42
4A fuses? Denman Control System 6 30-09-2004 21:28
OI Fuses? The Lucas Control System 4 09-02-2004 22:48
Fuses jdawson Electrical 13 23-01-2003 13:17
Where can I get 60 Amp Fuses -- that look like 30 Amp Fuses? Anton Abaya Chit-Chat 4 12-01-2002 14:09
