Go to Post The solution to that "problem" is obvious: practice driving. - Alan Anderson [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:58
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Height to lower pole?
Posted by brian nehring.
Student on team #100, Woodside Wildcats, from Woodside High School and NASA.
Posted on 2/2/2000 3:13 PM MST
I was wondering what the exact height is from the floor to the bottom pole (under the troughs, the one a robot needs to be under if it doesn't want to go over the ramp). I heard 2.5' before, but I don't know if that measurement was to the middle of the pole or the bottom. Any information would be greatly appreciated.
Thanks,
Brian Nehring
yertle38@hotmail.com
#0047 (ChiefDelphi)
Re: Height to lower pole?
Posted by Michael Betts.
Engineer on team #177, Bobcat Robotics, from South Windsor High School and International Fuel Cells.
Posted on 2/2/2000 3:46 PM MST
In Reply to: Height to lower pole? posted by brian nehring on 2/2/2000 3:13 PM MST:
: I was wondering what the exact height is from the floor to the bottom pole (under the troughs, the one a robot needs to be under if it doesn't want to go over the ramp). I heard 2.5' before, but I don't know if that measurement was to the middle of the pole or the bottom. Any information would be greatly appreciated.
: Thanks,
: Brian Nehring
: yertle38@hotmail.com
Brian,
Look in grid C-6 of the document http://www.usfirst.org/2000comp/Docs...01-A-page2.pdf and you will see that the height is 30 inches from the BOTTOM of the bar to the floor.
Having said that, it is advisable to always leave a wide design margin when dealing with FIRST specs.
Mike
Unread 23-06-2002, 22:59
#0047 (ChiefDelphi)
Posted by Joe Ross.   [PICTURE: SAME | NEW | HELP]
Coach on team #330, Beach Bot II, from Hope Chapel Academy and NASA/JPL, NASA ARC.
Posted on 2/2/2000 4:25 PM MST
In Reply to: Re: Height to lower pole? posted by Michael Betts on 2/2/2000 3:46 PM MST:
FIRST specified a tolerance of 1 inch for the height of the bar. Better not design you robot any taller that 29 inches if you want to get under the bar
Joe Ross
Team 330
#0047 (ChiefDelphi)
Posted on 2/3/2000 6:26 AM MST
In Reply to: Re: Height to lower pole? posted by Joe Ross on 2/2/2000 4:25 PM MST:
: FIRST specified a tolerance of 1 inch for the height of the bar. Better not design you robot any taller that 29 inches if you want to get under the bar
: Joe Ross
: Team 330
First ALWAYS specifies +/- 1 inch... :-)
[IMG] code is Off
three pole electric motors Solace Motors 10 11-08-2003 23:56
best height of stacks Ken Leung Rules/Strategy 2 13-01-2003 15:47
Railing height archiver 2000 1 24-06-2002 00:17
Fastest way to lower the bridge? archiver 2001 8 23-06-2002 22:32
height questions Team461 Off-Season Events 3 29-10-2001 21:51
