Go to Post Turning is overrated - Allison [more]
Unread 31-01-2008, 12:14
Re: IR_Sensor Programming
Originally Posted by Red Mage View Post
...a mysterious port j. We found where it is in the code but cannot understand how to use it.
Here's the background on the mysterious PORTJ.
The robot system variables we use (e.g., rc_dig_in18) are just aliases for connections or "windows" into the real PIC hardware. In the hardware, 8-bit registers are wired to hold the constantly sampled state from the pins (or the output state we want) and our aliases are just simpler ways to look at individual bits within these registers, one bit per digital I/O pin.
If you look in the file ifi_aliases.h you'll see these aliases defined for our 18 digital inputs:
#define rc_dig_in01 PORTBbits.RB2
#define rc_dig_in02 PORTBbits.RB3
#define rc_dig_in03 PORTBbits.RB4
#define rc_dig_in04 PORTBbits.RB5
#define rc_dig_in05 PORTBbits.RB6
#define rc_dig_in06 PORTBbits.RB7
#define rc_dig_in07 PORTHbits.RH0
#define rc_dig_in08 PORTHbits.RH1
#define rc_dig_in09 PORTHbits.RH2
#define rc_dig_in10 PORTHbits.RH3
#define rc_dig_in11 PORTJbits.RJ1
#define rc_dig_in12 PORTJbits.RJ2
#define rc_dig_in13 PORTJbits.RJ3
#define rc_dig_in14 PORTCbits.RC0
#define rc_dig_in15 PORTJbits.RJ4
#define rc_dig_in16 PORTJbits.RJ5
#define rc_dig_in17 PORTJbits.RJ6
#define rc_dig_in18 PORTJbits.RJ7
You'll notice all the values we use come through some register, such as:
-- PORTB for the interrupts on digital inputs 1-6
-- PORTH for inputs 7-10
-- PORTJ for inputs 11-13 and 15-18
-- PORTC for input 14
We can use any of these registers we wish or just use the aliases everyone's accustomed to. PORTH also has four pins grouped together that we could easily use by masking out (using the "&" operator) the other upper four bits in that register.
The demo code wants only the last four bits of PORTJ (15-18), so a simple way to eliminate the other unwanted values is to just truncate them by shifting the four bits we want to the right thereby pushing the four bits we don't want out of the variable altogether, e.g., 10001111 >> 4 becomes 00001000
The trick demonstrated with PORTJ allows the code to capture all the pin values at once in an instant of time. It just illustrates the potential window of error that could occur if the IR sensor changed the signals while we were testing them one at a time.
P.S. The excrutiating detail on PORTJ is described in the PIC18F8722_data_sheet.pdf that came on the CBOT compact disk in the KOP.
Unread 31-01-2008, 20:00
Speaker47 Speaker47 is offline
FRC #2198
Speaker47 is an unknown quantity at this point
Great the PortJ problem is fixed Thanks Alot....
But We have other difficulties,
1. We need to find a way to time how long the motors will run in autonomous, something like the "wait" function in Easy C..
2. Also, can anyone tell me how to turn on and off relay motors that I might use in autonomous??????
Unread 31-01-2008, 23:02
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
1. Add a counter or something similar:
if(x<100)
     pwm01=pwm02=150;
if(x>100
     pwm01=pwm02=127;
x++
2. Take a look at how they have the relays in the default code under the default_Routine() function
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 01-02-2008, 18:24
Red Mage's Avatar
Red Mage Red Mage is offline
Owner of Holistic Omniscience
FRC #1546 (Chaos Inc)
Red Mage is on a distinguished road
Send a message via AIM to Red Mage
Thanks, unfortunately by this time Miss Reiss told us to focus on the pneumatics since we haven't done that yet.
Don't Blink. Blink and you're dead. Don't turn your back. Don't look away. And don't Blink. Good Luck.
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
programming great_one411 Programming 2 15-02-2003 08:59
programming great_one411 General Forum 1 14-02-2003 11:28
Programming archiver 2000 1 23-06-2002 22:34
