Go to Post You are done with designing something, not when there's nothing more to add, but when there's nothing left to remove. - EricH [more]
Unread 30-01-2008, 21:37
citrusapocalyps citrusapocalyps is offline
FRC #2225
citrusapocalyps is an unknown quantity at this point
Start/Stop as one IR function?
What do you think? Would Start/Stop count as one function in Hybrid mode or two?
Unread 30-01-2008, 21:42
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Start/Stop as one IR function?
I'm pretty sure with the way they word it, they want each button to only control one function, as in separate buttons for stop and go. But if you can pull it off, you might be able to have stopping as part of your turn function, i.e. turn and stop. So to stop the robot you turn one way and then turn the other. Or make the button drive for one second and then stop.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Stvn's Avatar
Stvn Stvn is offline
FIRST Competition Competer
AKA: Steven Rhodes
FRC #0100 (WHS/CHS - WildHats)
Stvn is an unknown quantity at this point
Send a message via AIM to Stvn
I think it's two. From Team Update #3:
The actions that the Robot takes in response to the messages received should be
repeatable and predictable. In practical terms, this means that when the
RoboCoach presses Button #3, Action #3 always occurs. Robot responses that are
time-dependent or message sequence dependent are not allowed.
Unread 31-01-2008, 10:15
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Unfortunately, you can't use that as one state. As answered by the GDC in the Q&A:
Please refer to Team Update #3. With the guidance of the referenced "does it do the same thing every time?" litmus test, using a Signaling Device button to toggle Robot actions would not fit within the intent of Hybrid Mode. Nor would using the Signaling Device to step through a multi-step routine.
The messages sent by the Signaling Device can initiate more complex actions or routines that are completely pre-programmed on the Robot. The Signaling Device can also be used to transmit field state information instead of a specific command or action.
http://forums.usfirst.org/showthread.php?t=8008
Unread 31-01-2008, 10:33
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
From the Q&A responses I believe that it can be done. With the use of sensors you can activate a command that says, if x value is "a" then stop and if x value is "b" go.
This is only my interpretation and I am not a programmer or official answer giver.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 31-01-2008, 12:28
foote stepped in
AKA: E. Foote
FRC #0868
I think this might be a rule they cannot police, kind of like the re-use of code from year to year, or just fix during your fix it windows, or even like the maximum ball shooter speed in 2006.
Just use GP in determining your decision, and if you think its allowed, then go for it, otherwise don't. But have an alternative in mind if they specifically tell you "no."
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 31-01-2008, 12:36
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
they should ask you during inspection to test robocoach functions. I read this somewhere in the Q&A
Unread 31-01-2008, 13:03
GaryVoshol's Avatar
Cogito ergo arbitro
After searching the Q&A for "inspect", "inspects", "inspector", "inspectors", "inspection" and "inspections" I can find no such requirement. Do you have a better reference than "I read this somewhere"?
(since 2004)
Unread 31-01-2008, 22:34
Andy L's Avatar
FRC #1458
I'm not sure where I saw it but I am 100% sure I read somewhere that if asked you would have to show the inspector or a ref or a judge your hybrid controls and which button does what
a few rules about this subject:
<R65> Emphasis mine
communicate no more than four messages, states or conditions to the ROBOT (please refer to Rule <R69> and Rule <G01> for additional information) during any single
MATCH.
no more than 4 states I would say that having a button that changes states would count as two of your four messages
<R65> Emphasis mine
be able to switch between no more than four states or conditions (i.e. send no more than four messages)
pretty much the same thing just said again later in the rule
Team update #3 Emphasis mine
For example, consider a programmed sequence of actions such as “start driving forward,” “stop in place,” “turn left,” “raise arm,” “open gripper,” “close gripper,” etc. Each time Button #8 is pressed, the Robot advances one step through the sequence of actions. This would not be allowed.
Start and Stop would be steps and advancing steps is not allowed
Also keep in mind (can't find the quote in the rules for some reason) you must have a 3x5 notecard with all functions of your robocoach remote written on it.
I hope I helped
Unread 31-01-2008, 23:05
GaryVoshol's Avatar
Cogito ergo arbitro
Do you mean this rule?
<G49> ROBOCOACH Signaling – If the ROBOCOACH will be providing signals to the ROBOT,
then prior to the start of each MATCH the ROBOCOACH must place a Signaling Card in the
ROBOCOACH STATION. The Signaling Card shall be a 3-inch by 5-inch card listing the
one to four actions that can be commanded by the ROBOCOACH.
All you're doing is telling what you might do. You don't have to demonstrate it.
(since 2004)
Unread 01-02-2008, 00:50
Andy L's Avatar
FRC #1458
I'm not sure where I read it but I specifically remember reading you will have to show your hybrid functions if asked. But it could have been somewhere in Team Update #3 maybe I was thinking of because I talked about if we were to go up to someone like an inspector and keep pressing the button it would always do the same thing. Sorry for the misunderstanding. My main point is that Start/Stop button IS illegal
Originally Posted by Team Update #3
The litmus test would be “does sending the same message from the Signaling
Device result in the same action on the Robot every time the message is sent?” If the answer is “no” then it is probably not allowed.
Unread 01-02-2008, 01:10
Browzilla Browzilla is offline
Fearless Leader
AKA: David Vriezen
FRC #2530 (Team Inconceivable)
Team Role: Electrical
Browzilla is on a distinguished road
Send a message via AIM to Browzilla Send a message via MSN to Browzilla
I'm not sure about the legality of this, but what if my function were say, x=x+1. And then in the autonomous code was looped
if x is even, stop
else go
That way the button always preforms the same function, adding one, but you can achieve the desired result.
Yes? No?
Unread 01-02-2008, 01:13
if x is even, stop
else go
Yes? No?
I don't think that would pass. You're toggling states.
Unread 01-02-2008, 01:15
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
I would have to agree.... technically to task's are being achieved by one button
Unread 01-02-2008, 01:46
Fearless Leader
AKA: David Vriezen
I suppose that's what I get for trying to think this late.
Yeah, I suppose you're right.
(Job) Interview 102: Time and Group vs One-on-One Elgin Clock Career 6 01-10-2005 01:30
More than one joystick from one port Jmoo Programming 3 26-06-2003 18:01
The nerds go casting one by one... John Bono Chit-Chat 1 06-03-2003 22:12
Regionals start in one week - final advice or tips Mark Pierce General Forum 2 02-03-2002 18:49
