Go to Post This has to be the strangest trolling/spam/anything I've seen on CD, ever. - frcguy [more]
Unread 31-01-2008, 12:52
RoboPunk_994's Avatar
RoboPunk_994 RoboPunk_994 is offline
Need to know???????
AKA: Mike
FRC #2226 (Broncos)
RoboPunk_994 is an unknown quantity at this point
Send a message via MSN to RoboPunk_994
Pneumatics?????????
Does anyone know how to program the pneumatics? I am a nubie when it comes to them, We have it all hooked up but not programmed and I am not sure what to do...anybody want to help me out?
If we build it nerds will come!!
Unread 31-01-2008, 14:16
Re: Pneumatics?????????
Wire the pressure switch to one of the digital inputs.
Make sure that the digital input you'd like to use is enabled as an input in the "Controller Configuration" under Project.
Hook a Spike relay for the compressor and Spikes for each solenoid valve to RC Relay ports.
In the "Initialize" block add:
From "Function Blocks" -- "Pressure Switch" under "Outputs"
This will run the compressor when the pressure is low.
In the "OperatorControl" block add logic to activate each solenoid via a joystick button, etc. then add:
"Relay Output" under "Outputs"
For each of your solenoid Spike relays to actually work the solenoid.
A single action solenoid has two positions:
1) Forward=1,Reverse=0
2) Forward=0, Reverse=0
A double action solenoid is handled differently. If you wire them according to the diagram in the Spike Guide:
1) Forward=1, Reverse=0
2) Forward=1, Reverse=1
Pneumatics? falconmaster General Forum 6 19-01-2007 11:25
pneumatics adamoneDB04 General Forum 1 28-01-2003 11:59
pneumatics archiver 2000 3 23-06-2002 22:58
pneumatics archiver 2000 1 23-06-2002 22:42
Pneumatics archiver 2001 1 23-06-2002 22:36
