Go to Post I once heard someone say that Dean is "building an army of engineers." I disagree. I think he is building an army of the informed. - Gope [more]
Go Back   Chief Delphi > Other > Car Nack's Corner
Unread 31-01-2008, 13:17
Best Available Data
FRC #1778 (Chill Out!)
Re: Your game predictions - Car Nack Style
Originally Posted by ALIBI View Post
1: A Hybrid score of 28 points or more will actually be fairly common. Most teams will be able to move forward 30 feet (12pts), one team will be able to remove a trackball (8pts), at least two teams will be able to move forward, turn left and move forward again (8pts). A good hybrid bot, at least one per regional, will be able to cross two finish lines, a lane marker and remove at least one trackball (24 points).
2: Trackball control will either win for offense if you can control your own trackball or win for defense if you can keep your opponents trackball away from them.
3: Being able to place two trackballs at the end will make or break most matches. If defense can keep the trackballs away or descore a placed trackball, the defense will win.
4: Chipping away two points at a time doing laps while occasionally bumping your opponents trackball in a clockwise direction and occasionally bumping yours over your finish line will be valuable.
1) I don't believe so. Going straight for 50 feet is hard! It took us nearly 3 years to get it down (granted, we didn't spend the whole time working on it). And the real problem won't be that BLUEABOT1 isn't able to do it on his own, it'll be that BLUEABOT2 and BLUEABOT3 will be gunning for it at the same time, and someone will get clipped, then they'll spin out, and trap the rest of their alliance behind them. Additionally, it will cost nearly all teams at least 5 seconds to stop, knock the ball down, and then start up again. Not to mention, it's probably worth your time (if you hurdle) to have hold of that ball from the start of tele-op.
3) Why not just hurdle it and ensure you get the points? If you place, you get 12 points that can be taken away, if you hurdle, you get 8 guaranteed points. While this builds up over two trackballs, will you get 2 good hurdlers together in a seeding match? I'd bet maybe twice a regional. So I see hurdling as more valuable unless you absolutely need those 4 points, and can't get them racing around the track in the time it takes you to position that ball.
Car Nack Predicts 01/08/07 Car Nack Car Nack's Corner 47 22-03-2007 10:07
Car Nack Predicts #4 Car Nack Car Nack's Corner 0 29-03-2004 11:18
Car Nack predicts #3 Car Nack Car Nack's Corner 2 03-03-2004 09:24
Car Nack In Disbelief archiver 2001 9 23-06-2002 22:47
