Go to Post In any case, I'd like to remind everyone to practice gracious nonexpansionalism while in your pit. - sanddrag [more]
Unread 31-01-2008, 13:52
CodeMaster 1388 CodeMaster 1388 is offline
1388 Programmer
AKA: Chase
FRC #1388 (Eagle Robotics)
CodeMaster 1388 is an unknown quantity at this point
Sensor issues, help?
Ok so originally we were going to use pots to get the location of some of our components as they moved, unfortunately, the shafts have been built in a way that makes this impossible. If you've seen the most recent image of our robot, you can see that there're metal disks on one of the shafts lower on the bot. We have the idea of marking the disk, and using an optical rotation sensor in order to read how many lines have past by, and thus the position of the component. The only problem is I can't find anywhere to buy an optical rotation sensor. The exact kind of sensor I'm talking about can be found at this site, under Optical Rotation Sensor.
http://www.cyanogen.com/help/maxdome...Controller.htm
If you know anywhere we can find these, please post it here, I'm having no luck.
Unread 31-01-2008, 14:09
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Sensor issues, help?
You don't need a special sensor... any reflective sensor will work to detect the changes from light to dark. One of the best sensors for this task is the Banner sensor from the 2004 KoP. Take a look in the cabinets to the left of the clock in your shop... I wouldn't be surprised if there's still a tangled mess of yellow plastic Banner sensors down there.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 31-01-2008, 21:58
Gdeaver Gdeaver is offline
FRC #1640
If you could mount a magnet on the end of the shaft then one of these non-contact rotary position sensors could work. Nice thing is they give absolute position by reading an analog input - no interrupts. Works just like a continuous rotation pot.
http://www.gmw.com/magnetic_sensors/ametes/360ASMC.html
Sensor Issues Brian Connors Electrical 5 13-01-2008 09:48
HELP!!!! EasyC Compiling Issues Wbrown0389 Programming 8 29-01-2006 09:18
Gear tooth sensor issues Nine9cracker Electrical 2 17-01-2006 02:37
help!!!-Gear Legality Issues? kilpatrick Technical Discussion 1 17-02-2002 09:11
