Go to Post If you are adult enough to be a participant in this program, then you are adult enough to act like an adult. - Beth Sweet [more]
Unread 31-01-2008, 14:35
Re: How to wire solenoid valves????????
Yes, you need a spike controlled via an RC Relay port.
The solenoid connects to the Spike M+/M- terminals.
A single-action solenoid connects the red wire to M+ and the black wire to M-.
A double-action solenoid (two sets of wires) connects one red to M+, the other red to M-, and both black ground wires to the ground on a fuse block or other appropriate ground connection.
Unread 31-01-2008, 15:45
REVving up for a new season
FRC #2848 (All-sparks)
the easiest solution I have used is just to connect the black wires to the V- input on the same spike.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
where are double solenoid valves placed Reaper40 Pneumatics 5 28-01-2007 15:54
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
Q&A Discuss: Cylinders + Solenoid valves CD47-Bot Extra Discussion 1 05-02-2003 17:21
Cylinders + Solenoid valves Greg General Forum 2 28-01-2003 09:29
Does anyone have extra solenoid valves????? Elgin Clock Pneumatics 5 18-02-2002 12:43
