Thread Tools |
Rating:
Display Modes |
Re: IGES and STP file modification
Tom
If you have the SolidWorks Education Edition or your mentor has a SolidWorks Commercial Edition you can utilize the Add In called Feature Works to make non parametric features from IGES/STEP/SAT into recognized ones. Also from within SolidWorks, you can select on a face from imported geoemtry, create a new sketch and extract geometry in a Sketch with the Convert Entities tool. This technique is usually the most helpful because you really dont want to spend a great deal of time converting all imported parts in an assembly if you just want to add a few holes to a mounting plate. Marie |
| How to use the data obtain in one C file to another C file? | tommy_chai | Programming | 8 | 11-01-2008 02:17 |
| [OCCRA]: Belt material and wheel modification | JBotAlan | OCCRA Q&A | 1 | 19-09-2007 21:15 |
| SLDPRT to IGES - Can someone convert for me please? | sanddrag | Inventor | 1 | 31-05-2006 22:05 |
| IGES Model of Large CIM Motor | Madison | SolidWorks | 7 | 16-01-2006 13:27 |
| How do we convert a modified user routines file into a valid .HEX file | HuskieRobotics | Programming | 13 | 28-02-2004 12:12 |
